My new Project the 931
Goto page Previous  1, 2
Manic_931
PostPosted: Fri Mar 10, 2006 6:39 pm    Post subject: Thanks guys Reply with quote
I am definitely gonna do the IC and an EFI system (if budget allows )
One more thing, what would i be able to do to bring down the turbo lag?
Thanks a mil guys
'79 931 LHD (White/Tan Leather)
Buying an old porsche is like marrying a gold digger... only you never had lots of money to begin with...
flosho
PostPosted: Sat Mar 11, 2006 1:48 am    Post subject: Re: Thanks guys Reply with quote
Thanks a mil guys
You shouldn't have much if any lag at all on stock boost. My car is US spec and it builds full boost at around 2400RPM I'd say. Even with a few more PSI it can't be that far behind in spool up. With an intercooler, the lag is gonna be a little worse depending on the setup. (ie. bends, pipe diameter, length of pipe, etc)
A free flowing exhaust may help lag a little, while it should give you some good increases in power as well.
[This Space For Rent]
Faith
PostPosted: Sat Mar 11, 2006 5:33 am    Post subject: Re: Thanks guys Reply with quote
Thanks a mil guys
On my 944 Turbo S I installed an Lindsey Boost enchancer. So the Turbo Boost comes 600rpm earlier. And when it is possible, I will do this also on my 924 Turbo.
The little world of my Porsches: www.fette-platte.com
bulldog fred
PostPosted: Sun Apr 02, 2006 12:06 am    Post subject: intercoolers Reply with quote
Hi i am from England that counts as urope i am with sandy on this mine has a mondeo intercooler on it at the moment and a nice water injection set up so i can run my boost to what 0.9 bar would that be the safe limit , i also have a 944 intercooler siiting around at the moment so if you have a bigger intercooler would you get better resulsts by beeing abl to put more cold air in,if there is not much diffrence, then i would seel the 944 cooler, the mondeo is fitted down below infront of the radiator and i have a new rad made for better flow and a bigger eletric fan and i have no troubles with the over heating.
by the way i am running at 0,8bar at the moment withthe water injection a friend of mine owns a imprezza anew one he thinks mine is faster than that, [/list][/code][/quote]
bulldog fred
1980 931 s1 silver
1982 931 s2 red - moded intercooler, water injection, avo sports suspension 944 turbo sway bars,green stuff brakes (brilliant)
flosho
PostPosted: Sun Apr 02, 2006 2:08 pm    Post subject: Reply with quote
fred, do you have any pictures of your setup? Sounds sweet!
Page 2 of 2
