Front of engine service finished - suspension ongoing
that_jer_guy
PostPosted: Sun Mar 19, 2006 12:15 am    Post subject: Front of engine service finished - suspension ongoing Reply with quote
Thank you all for the advice after my 1st post (especially gohim).
I have followed it to the letter and I am glad for having done it.
Replaced: timing and balance shaft belts, oil cooler seals, water pump and front oil seals for everything except the cam shaft. I also replaced all the idler gears for the timing belt. The good news is that the belt I replaced was almost new so I bet the car had been serviced recently. I could still read all the writing on the old belt and there were no cracks and very little wear on the belt teeth.
The bad part was I found damage to the ignition rotor and balance shaft sprockets (some jackass used a pair of channel locks hold the sprocket while he was undoing the balance shaft bolt and managed to break off half a tooth) so I replaced those while I was at it.
Right now I am taking the front lower control arms off. I am going to paint these up to keep them from rusting any more. There is also some wear/damage to the rear bushing on the passenger side so I'll have to replace that.
Then a little bit of painting up the underbody to stop the rust and I'll be done. It will be time to hit the road just in time for the good weather.
First autocross: April 30th in Brampton (suburb of Toronto).
Stu2j
PostPosted: Sun Mar 19, 2006 2:47 am    Post subject: Re: Front of engine service finished - suspension ongoing Reply with quote
Cost?
-Stu
924 owner since 1988
924S owner since 2002
Click here to view them:
that_jer_guy
PostPosted: Sun Mar 19, 2006 4:16 am    Post subject: Re: Front of engine service finished - suspension ongoing Reply with quote
Stu2j wrote:
Cost?
For the whole job including shipping and taxes parts cost me about $875 CDN. $150 of that was for the rotor and balance pulleys that I should not have had to replace. Add $20 for Prestone and deionized water. Also not included is the belt tensioning tool cost.
Most expensive part was the water pump at $195. 2nd most expensive was engine seals at $154 (entire front of engine seal package). The rest of the parts ranged between $35 and $95.
Stu2j
PostPosted: Sun Mar 19, 2006 4:54 am    Post subject: Re: Front of engine service finished - suspension ongoing Reply with quote
that_jer_guy wrote:
Stu2j wrote:
Cost?
Using my handy dandy converter that looks like about 755 US. Not bad at all.
Thanks
-Stu
Llamaguy
PostPosted: Sun Mar 19, 2006 1:13 pm    Post subject: Reply with quote
the rotor should have only been about $10 US. They carry them at autozone.
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
that_jer_guy
PostPosted: Tue Mar 21, 2006 1:04 pm    Post subject: Reply with quote
I'll remember that for next time. The OEM one that I bought got ended up $60.
I thought that was a little steep but I guess it is my own fault for not shopping around.
'87 924S
PostPosted: Tue Mar 21, 2006 1:16 pm    Post subject: Reply with quote
$10 is not going to buy an OE Bosch distributor cap.
I don't buy the generic ones anymore because they are made of inferior materials.
Very often the cap itself is made of a cheap plastic, instead of the more expensive dielectric material the the OE cap is made from. And the terminal contacts on the generic caps often have aluminum alloy contacts which have a higher resistance (more loss through the cap when the voltage passes through to the plug wires), and burn up much faster than the Genuine Parts, which usually long lasting brass. I suggest that people stick with the real parts myself, and stay away from generics.
Llamaguy
PostPosted: Tue Mar 21, 2006 1:40 pm    Post subject: Reply with quote
What do you consider long lasting? I almost guarantee that it shouldn't last longer than 3 years, because you'll probably end up breaking it getting it off for the belt replacement. I know I did.
Kaos
PostPosted: Wed Mar 22, 2006 2:09 am    Post subject: Reply with quote
I know I mentioned this before, but FYI here is the Detroit region auto-x schedule.
I will be an instructor at the school.
http://www.detroit-scca.org/schedule.asp?pg=1
Congrats on finishing the work.
that_jer_guy
PostPosted: Thu Mar 23, 2006 12:06 pm    Post subject: Reply with quote
Kaos wrote:
...here is the Detroit region auto-x schedule.
Thank you.
I am anxious to try one of the Detroit region solo events. I'll let you know before hand if I can make it to one. Right now I'll be shooting to make it to the May 29 event. The Ontario event is in Picton that weekend. I don't think I'm going to go all the way to Picton.
Waterford Hills in July?
I would really enjoy that. Great place.
Been on it a number of times for lapping days with my Civic.
'87 924S
