Problem accelerating
rg-series
PostPosted: Tue Feb 28, 2006 4:31 pm    Post subject: Problem accelerating Reply with quote
I recently purchased an 80 931, that runs but has some issues. It is very slow and at about 2500 RPM the engine mis fires. In neutral it revs up past 3500 withough any problem. at 2500 RPM I was at 5 lbs of boost. Does this sound like timing or fuel delivery?
PostPosted: Tue Feb 28, 2006 4:51 pm    Post subject: Reply with quote
You don't need to double post.
The 931 Tech. forum is your best bet for replies. You can post your questions here in the general forum but if they're 913-specific, you really should only post them in the 931 Tech. forum.
rg-series
PostPosted: Tue Feb 28, 2006 11:57 pm    Post subject: Reply with quote
sorry, there doesn't seem to be as much traffic in the 931 forum, and this problem could happen on 924's also, as I'm not positive it is turbo related.
helowrench
PostPosted: Tue Mar 07, 2006 5:03 am    Post subject: Reply with quote
Almost sounds like a fuel delivery (filter) or ignition (distributor or coil)
problem
Rob
