rg-series
Joined: 25 Feb 2006 Posts: 17 Location: Tempe, Arizona USA
Posted: Tue Feb 28, 2006 4:24 pm Post subject: setting idle speed |
| The idle on my 80 931 is up at about 1300 RPM right now, and I want to bring it down where it should be. How worried should I be about adjusting the idle speed back down ONLY if I have a CO meter hooked up? |
Posted: Tue Feb 28, 2006 6:20 pm Post subject: |
Not worried at all.
Over the range of engine speeds you're talking about (500 - 1500 rpm), changing the idle speed will have next to no effect on the CO content. Just do it. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Tue Feb 28, 2006 6:57 pm Post subject: |
Be aware that its not as simple as adjusting the screw on the throttle body.
IIRC the 931 has DITC and EIS.
You may have to talk about it on the 931 forum. _________________ Porsche 924 1984 (UK import) NA
Posted: Wed Mar 01, 2006 2:19 am Post subject: |
Actually, the 931 got DITC ignition with built-in EIS starting in '81. Same for the 924na - it got TCI-H ignition with seperate EIS starting in '81 (maybe only US/Can cars though). -So, should be no EIS (electronic idle stabilization) or DITC on an '80. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Wed Mar 01, 2006 6:15 am Post subject: |
Thanks Smoothie. _________________ Porsche 924 1984 (UK import) NA
