Runs great cold: won't run warm-Need wisdom!
Goto page Previous  1, 2
undrprzur
PostPosted: Sun Feb 05, 2006 3:51 pm    Post subject: Reply with quote
Ok guys, I will check the fule pumps, infact the external is new 4 Months, but hey anything can happen. The retard wire is good and well connected. I don't have a spare ditc, might have to buy a good one, SO IF ANYONE has One please post $. Will remove and test the tem sensor.
Question, does the temp sender on the housing under the Distributr have any significance on this situation?
Without a doubt, I am grateful to this board.
81 931 Always on Boost.
PostPosted: Sun Feb 05, 2006 4:55 pm    Post subject: Reply with quote
undrprzur wrote:
Question, does the temp sender on the housing under the Distributr have any significance on this situation?.
No the sensor/s back there wouldn't have anything to do with retarded timing. The air temp sensor at the throttle body could though as I think Paul mentioned. Another possibility is EIS (electronic idle stabilization) - if your idle speed isn't set correctly, EIS will set it for you by altering the timing, so if idle's set too high, EIS would retard the timing (at idle only) to bring the idle speed down. Did you check the timing only at idle? -Or at higher RPMs (2000-2500+) also? A defective air temp sensor would affect the timing at all times (idle, part throttle, full throttle).
PostPosted: Mon Feb 06, 2006 12:26 am    Post subject: Reply with quote
I was thinking the problem might be is that the temp sensor is sending false signals to the DITC. If it is sending temps that are higher than actual, at some point the DITC might believe they are critically high enough to reduce the timing drastically.
Easy to check, just follow the procedure I posted.
Tigger937
PostPosted: Mon Feb 06, 2006 5:10 am    Post subject: Reply with quote
Make sure the installed external pump is the correct one for 1981 931, ie., Bosch #0.580.254.967 or equivalent replacement.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Page 2 of 2
