more power
r924s
PostPosted: Mon Jan 23, 2006 8:10 am    Post subject: more power Reply with quote
does ne 1 know how i can get more power outa my 87 924s it seems lacking i need an afordable price for something that gives me more hp
PostPosted: Mon Jan 23, 2006 9:24 am    Post subject: Reply with quote
Sorry, there isn't any cheap way to get more power from a 924S 2.5L engine. You can a slight hp improvement (5hp?) by installing a "chip" in the ECU ($300-$600), but that will require the use of preimum grade fuel at all times.
If you have an automatic tranny, you could convert to a manual tranny. This would free up the approximate 20% horsepower loss due to transmission loading. The cost shoudl be close to $1000, if you do all of the conversion work yourself, and shop for a used transmission (plus the other parts that will be needed).
The least expensive way to add significant hp is to sell your 924S, and buy a 951 (944T).
r924s
PostPosted: Mon Jan 23, 2006 9:31 am    Post subject: Reply with quote
wut about gettin after market air intake kit and headers and polsihing the intake system
where can we get after market intake kits and or headers
PostPosted: Mon Jan 23, 2006 9:45 am    Post subject: Reply with quote
Forget that stuff, you'll hardly notice a difference.
Do a search on supercharging if you have several thou to spend.
Here's some info from Speed Force Racing:
SFR Level 1 944 Supercharger system-$3999
SFR Level 2 944 Supercharger system-$4999
SFR Level 3 944 Supercharger system-$5999
Or there are members on this board who have cheaper solutions, do a search....
ESC944
PostPosted: Mon Jan 23, 2006 2:16 pm    Post subject: Reply with quote
I would suggest a search using just the key word supercharger.
Then you will find more than enough information to consider including some "Porschographic images" great stuff.
Of course will also see posts about turbos as well or adding power.
Like Turbocharging an NA, etc... same applies to the 2.5 as does the 2.0 and engine is an engine, each has its limits.
Seriously their is information about superchargers, about turbochargers, about nitrous, about adding power in general.
Note to mention examples.
SFR has a lot of good stuff and considering their kits used to be in the 6-8,000 range, they have gotten better.
Their are member doing it their self or have done it with the 2.0, and you could follow the example to do the 2.5!
r924s
PostPosted: Wed Jan 25, 2006 1:05 pm    Post subject: Reply with quote
thx im going to look into supercharging it and hopefully it will fit my budget if not i guess ill have to make do w/ adding small bits of hp at a time
