Rough/ low rpm's at idle. At speed = perfect.
Neil924
PostPosted: Sat Dec 17, 2005 10:24 am    Post subject: Rough/ low rpm's at idle. At speed = perfect. Reply with quote
A 1988 924S, has been running fine but recently at idle the rpms drop, then come back up. It sounds like it isn't getting enough fuel, and is about to die, but it never does. It just has a really rough idle, however under acceleration and cruising it acts perfectly fine. Any ideas? I was thinking maybe a fuel sending problem (i.e. fuel pump).
Any ideas?
P.S. It's not my car. Could it be the injectors or timing or air fuel mixture?
Thanks.
Neil
PostPosted: Sat Dec 17, 2005 2:33 pm    Post subject: Reply with quote
The problem that you describe is a classic symptom of bad engine mounts.
edh
PostPosted: Sun Dec 18, 2005 1:20 am    Post subject: Reply with quote
Could possibly be lots of things apart from mounts
Does it vary between hot & cold running?
If you hold it on the throttle at 1k rpm do you get any vibration?
current - '90 944S2, '00 986S,
ex - '90 944 turbo '86 924S, '88 924S
Neil924
PostPosted: Sun Dec 18, 2005 2:42 am    Post subject: Reply with quote
Thanks a bunch.
Techno Duck
PostPosted: Sun Dec 18, 2005 3:51 am    Post subject: Reply with quote
Neil, do the RPM's fluctuate or do they stay constant? If they stay at a constant the normal idle RPM (about 900) then its probably your engine mounts. If it idles very low, it could be a idle stabilizer valve or your TPS.
1987 Zermatt Silver Porsche 924S <-- Sold in Nov. '04
1987 Guards Red Porsche 944 <-- Sold in Jan. '08
1988 Guards Red Porsche 951 <-- Das Boost
Llamaguy
PostPosted: Sat Jan 14, 2006 2:50 pm    Post subject: Reply with quote
check the fuel pressure regulator and the dampener, sounds like what was happening to mine.
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
Slam
PostPosted: Fri Jan 27, 2006 5:21 pm    Post subject: Reply with quote
Does engine temperature affect it? Will it idle properly if the throttle switch is adjusted so it doesn't send an on-idle signal?
