Dizzy Fitment
bass gt
PostPosted: Sat Dec 24, 2005 8:34 pm    Post subject: Dizzy Fitment Reply with quote
Guy's,
Do any of you know whether the N/A dizzy will fit into a Turbo head? Reason is i am thinking of using it as a cam timer for sequential fuel injection if it does.
Regards,
Steve
sequential
PostPosted: Sun Dec 25, 2005 3:49 am    Post subject: Reply with quote
Yes the n/a will fit we did the same thing for the same purpose.
928 gts prototype
baby blue engine block
steam in 1,2,3,4 sometimes
cold star issues while on stands
112 whp with new 4 valve head and MIS 2
Raceboy
PostPosted: Sun Dec 25, 2005 5:10 am    Post subject: Reply with quote
Crank trigger would be better idea. Why? Because distributor will have a play, no matter how tight you'll make it and timing belt will stretch also, in high rpms up to 4-5 degrees.
NA dizzy is only good for short-time replacement or sth.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
bass gt
PostPosted: Fri Dec 30, 2005 5:59 am    Post subject: Reply with quote
Raceboy,
I plan to use a crank trigger as well, but have been looking into the merits of sequential injection over grouped. As i plan to use fairly large injectors, around 440cc/min, i am concerned about fouling the plugs on start up. Also, am i right in assuming sequential would be more fuel efficient, as only the correct injector is being fired, rather than in pairs, with one shot of fuel going to waste.It may sound a silly thing, but as my car has a 14 litre fuel tank, i would rather not be filling up every 5 laps!!
Regards,
Steve
sequential
PostPosted: Fri Dec 30, 2005 5:23 pm    Post subject: Reply with quote
Steve batch with 440cc inj is not a problem , you would need much larger than this to be full sequential all the time! at full throttle race conditions
you will need x amt of fuel to keep the engine happy anyway. in your short sprint races not sure how much benifit you will see. We run sequential to make number 4 happy.
928 gts prototype
