Lord Fester
Posted: Wed Oct 19, 2005 10:56 am Post subject: |
| Paul wrote: | Congrats, I'm glad to hear it runs.
That was a good idea (collapsing the roll pin), one guy I know used a hammer and chisel to break the mount. Your way is better and cheaper! |
Thanks.
Believe me, the thought of breaking the mount had crossed my mind...
Once I got it running, I've found tha the power steering pump has lost some fluid. I may have a line to replace, but I haven't put it up on the ramps yet. The chain starts... Did I mention it was against my better judgement to get a car that has sat for an extended period?  _________________ '87 924S slushbox (nice tourer)
'87 VDub Cabriolet "hers"
'87 VDub Cabriolet "ol skool" mine
'82 Scirocco (organ donor)
Living the dream. One broken part at a time... |
Lord Fester
Posted: Mon Dec 05, 2005 3:48 am Post subject: Follow up - still not running! |
Here we go again.
The beast ran for two days. Long enough to pass local emissions testing and inspection at least. The following day it wouldn't restart.
I Decided to have it towed to a local sports car guru (since I've got a few family emergencies that have taken up all of my time and money) and he re-gapped the DME sensor for the starting circuit. (The oscilloscope showed a weak signal). Fired right up and off I went.
The next morning (I'm a 3rd shifter) at work it wouldn't start again. Misfiring like it had jumped a tooth on the timing. I stopped right there and called for a pickup. Told the shop to i.d. the problem and I'd take care of the fix if it was an easy one. The shop has had it for the last 3 to 4 weeks "playing with the problem" at odd times. I haven't pushed them hard as I wanted to:
1. Not have it be a priority in his bay. $$$
2. Make sure it was truly "fixed" before taking it out again.
Well, every time they would get a strong signal from the TDC sensor it would fire right up. About 3 to 6 starts later the same cycle would begin all over and it wouldn't restart.
Finally got a call last Friday. IF you whack the Control Box, it starts fine!
So now to source a new (or used) "brain".... It sounds like a bad solder joint or loose wire, so I'll try splitting the box to look for any obvious problems. _________________ '87 924S slushbox (nice tourer)
