Annoying Squeel in Heater blower motor when cold
Blas
PostPosted: Wed Oct 12, 2005 12:24 pm    Post subject: Annoying Squeel in Heater blower motor when cold Reply with quote
Anyone have a solution for the annoying squeel in my heater blower motor when it is cold? Motor works fine, and disappears when it warms up...suggestions..it's a 1979 - 924....Thanks all
Tigger937
PostPosted: Wed Oct 12, 2005 1:50 pm    Post subject: Reply with quote
Had the same problem a few years back. Just removed the plastic covering/housing under the hood and placed several drops of teflon based lubricant on the motor shaft and that solved it.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Blas
PostPosted: Wed Oct 12, 2005 11:38 pm    Post subject: Reply with quote
Excellent...I'll try it over the weekend....
Blas
PostPosted: Sun Oct 16, 2005 9:12 am    Post subject: Reply with quote
"...removed the plastic covering/housing under the hood..."
OK...under hood....Black plastic housing....3 black plastic pins....plastic cover didn't budge....I hate to break it by accident...did I miss something?
Tigger937
PostPosted: Sun Oct 16, 2005 9:54 am    Post subject: Reply with quote
No need to remove the black plastic housing. Just shine a light in there and you'll see the motor end shaft. Get a long narrow tube, poke it between the holes in the screen and squirt oil on the shaft.
1981 931 (Concours)
D Hook
PostPosted: Sun Oct 16, 2005 10:25 am    Post subject: Reply with quote
If you happen to break it, I think I've got an extra, if you need one.
I shot some lube with a tube and it worked pretty good. May have to do it again in the future but this will certainly quiet it down for awhile.
'80 924 n/a SOLD
Tigger937
PostPosted: Sun Oct 16, 2005 11:04 am    Post subject: Reply with quote
Yeah, I had to do mine twice, then it was fine.
1981 931 (Concours)
Blas
PostPosted: Mon Oct 17, 2005 1:02 am    Post subject: Reply with quote
Perfect....worked like a charm....thanks
