Tigger937
Posted: Thu Oct 13, 2005 9:46 am Post subject: |
| gautney wrote: | | I checked the system for blockage, have bleeded, replaced thermostat, fan comes on between 1/4 and 1/2 mark, seems to get hot when it is idle. Thanks for the advice! |
You need to be more descriptive about what's happening and the symptoms surrounding it. What exactly do you mean when you say, "seems to get hot when it is idle"??? Why makes you think it's getting hot? We need more data!  _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Neil924
Posted: Thu Oct 13, 2005 9:55 am Post subject: |
| Tigger937 wrote: | | gautney wrote: | | I checked the system for blockage, have bleeded, replaced thermostat, fan comes on between 1/4 and 1/2 mark, seems to get hot when it is idle. Thanks for the advice! |
You need to be more descriptive about what's happening and the symptoms surrounding it. What exactly do you mean when you say, "seems to get hot when it is idle"??? Why makes you think it's getting hot? We need more data!  |
And we need more pictures of your car. |
gautney
Joined: 11 Oct 2005 Posts: 19 Location: Salt Lake City, Utah
Posted: Thu Oct 13, 2005 9:59 am Post subject: |
What I mean by idle is when it sits for a period of time say 10-15 min's it will start to overheat (overboiling). _________________ 1998 Boxster
1979 924
1962 356b |
numbbers
Posted: Thu Oct 13, 2005 10:00 am Post subject: |
1/2 inch of deflection on the belt is the normal setting. _________________ 1980 924 Turbo |
bryanc
Joined: 27 Feb 2003 Posts: 233 Location: San Antonio, Texas
Posted: Thu Oct 13, 2005 12:40 pm Post subject: |
As tiger 937 said, are the fans turning the right direction. The connector to the fan disintregrated on my 82 and I connected the wires backwards. That makes the fans spin backwards. Won't work that way. _________________ '84 944
I'd rather have a bottle in front a' me than a frontal lobotomy
Tom Waits |
924 turbo
Posted: Thu Oct 13, 2005 4:00 pm Post subject: |
My guess, assuming your fans are working properly, is that your radiator is clogged. You may need to get it serviced at a radiator shop (rodded out). Last time I had this done, it was under $50. _________________ Jon Furst |
gautney
Posted: Fri Oct 14, 2005 2:12 am Post subject: |
Fixed it last night, thought about what Numbbers said and checked the fan belt, there was a 1/2 inch of play but when I turned it by hand it had alot of slippage. Replaced the belt and it seems to be fine. Thanks everyone for your help. This is an awsome board!!! _________________ 1998 Boxster
1979 924
1962 356b |
