what ange is the engine at?
MikeDanger
PostPosted: Thu Sep 29, 2005 7:49 am    Post subject: what ange is the engine at? Reply with quote
working on my headers here, need to find out what angle to set my guide at so the will fit in the engine bay
It was either this or a giant box of legos
MikeDanger
PostPosted: Thu Sep 29, 2005 11:23 am    Post subject: Reply with quote
ANYONE???
does this look about right??
PostPosted: Thu Sep 29, 2005 11:44 am    Post subject: Reply with quote
It's either 40 or 42 degrees, not exactly sure, 42 seems to ring more bells.
PostPosted: Thu Sep 29, 2005 12:04 pm    Post subject: Reply with quote
I measured 50°, but that would be as tilted up from horizontal.
Looking at it the other way, tilted down from vertical, it would be 40° - but then I couldn't guarantee that the driveway here's perfectly level. In any case, looking at your picture, it looks like you need to tilt it some more.
endwrench
PostPosted: Thu Sep 29, 2005 2:06 pm    Post subject: Reply with quote
I do mockups at 40°
Todd
PostPosted: Thu Sep 29, 2005 2:09 pm    Post subject: Reply with quote
I read 40deg somewhere.
MikeDanger
PostPosted: Thu Sep 29, 2005 2:18 pm    Post subject: Reply with quote
Actually ive been measuring it at 38deg, However i think its best to do it at 10 deg less, for a couple reasons. the first is the part that causes the spacing trouble is the strut tower, which is at about 10, so that makes it 28 deg. also, the more determining factor.. I measure about 6" of clearance between the block and the chasis, and 2" between the top of the head and the strut tower.
There is a little more angle than the picture shows, the angle of the camera makes it seem like less.
If you did them at 40deg i believe youd think you have more room than you actually do.
also the top of the head is at 10 deg, so the angle i cut was about 18 then screwed a board to the other board that goes across the top of the head.
Note: the assembly is not tilted the camera was.
endwrench
PostPosted: Thu Sep 29, 2005 2:27 pm    Post subject: Reply with quote
What are building the headers from? Looks pretty thin for a turbo unless it is stainless. What will you be welding with?
Todd
MikeDanger
PostPosted: Thu Sep 29, 2005 2:46 pm    Post subject: Reply with quote
thats just what im mocking them up with
