flosho
Posted: Tue Aug 09, 2005 8:40 am Post subject: Removing the tail lights? Any trick to it? |
Is there any trick to removing the taillights on my 81 931? I took the bulbs out and the 6 nuts off the screws... but the taillights are like stuck in there, i pushed on them quit a bit and they didnt budge!  _________________ [This Space For Rent] |
Posted: Tue Aug 09, 2005 10:08 am Post subject: |
They are sealed with a thick band of goo ( I call it "Gorilla Snot").
You can try heating up the edges from the outside with a hair dryer, but usually they can be pushed out by pushing on the screws with a hammer handle or a block of wood |
Vince Ponz
Posted: Tue Aug 09, 2005 10:35 pm Post subject: |
You can try to heat the seals. It is a hard gentle push top get them out. Make sure you have all the little nuts off. One is hidden on the bottom.
Once you get to see light between the parts get some heavy string and thread it through and pull it around. Cleaning the black stuff is hard too. Good luck. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Posted: Fri Sep 02, 2005 5:21 pm Post subject: |
When you replace them, you will need more 'Gorilla Snot' (as Paul puts it!) and plenty of it or else the back of your car will fill up every time it rains.
The lights don't fit flush against the metalwork, but are designed to sit on a bed of 'GS'. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
leadfoot
Posted: Sun Sep 11, 2005 11:02 am Post subject: |
You might be able to use something like a heavy duty needle and some fishing wire to pierce the GS and break the seal.
Leadfoot _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Sun Sep 11, 2005 11:14 am Post subject: |
| Paul wrote: | | They are sealed with a thick band of goo ( I call it "Gorilla Snot") |
You just know that someone is gunna use GS as a product name for this stuff. I can see it now, big picture on the packaging of a Gorilla holding a tissue & everyone saying "Why do they call this stuff "GS".
Funniest product name I've found is starter fluid called "Start Ya Bastard"! _________________ TJ
Silver '82 924 NA 5-Speed Manual |
Posted: Sun Sep 11, 2005 11:18 am Post subject: |
Different product, I guess I'll have to rename that goo....
http://store.gearnut.com/gorillasnot.html _________________ White 87 924S "Ghost"
tj924
Posted: Sun Sep 11, 2005 11:23 am Post subject: |
Thats priceless! "NOTE: If you use too much, the Snot may take a little longer to dissipate..."
Posted: Sun Sep 11, 2005 11:29 am Post subject: |
Nah, mate, the one that made me laugh was:
HOW DO I USE SNOT?:
Apply Gorilla Snot sparingly to your fingers or work a small amount into your pick _________________ White 87 924S "Ghost"
D Hook
Posted: Mon Sep 12, 2005 1:41 am Post subject: |
| tj924 wrote: | | Paul wrote: | | They are sealed with a thick band of goo ( I call it "Gorilla Snot") |
Funniest product name I've found is starter fluid called "Start Ya Bastard"! |
Hey! They stole that from me! That's what I call my car! _________________ '80 924 n/a SOLD |
