WUR - Warm Air Regulator - or Control Pressure Regulator
IXLOR8
PostPosted: Mon Sep 05, 2005 10:23 am    Post subject: WUR - Warm Air Regulator - or Control Pressure Regulator Reply with quote
What is the best way to remove and replace the WUR? I have checked Haynes, Clymer and Chilton on the proper way of removal. No detailed info.
Any ideas? Estimated time to R & R?
Wisconsin
PostPosted: Mon Sep 05, 2005 10:28 am    Post subject: Reply with quote
well there isnt really any info that I am aware of to rebuild them, but perhaps do a board search,
as per removal/reinstall,
take the coil out of its bracket, and you can then get at it,
the tools needed for the WUR, a 12mm wrench, a 14mm wrench, and a 6 mm allen key,
to get the coil out you will need a 10mm wrench/socket, and possibly a flat head crewdriver,
that should be all, just dont drop the 4 crush washers for the WUR, and when you reinstall do NOT over torque the banjo bolts as they tend to break easy and then you will be in a bind trying to find one.
3 928s,
IXLOR8
PostPosted: Mon Sep 05, 2005 10:52 am    Post subject: WUR Remove and replace Reply with quote
Do you remove the WUR first than the lines? Or lines and then WUR?
Thanks for your help.
Wisconsin
PostPosted: Mon Sep 05, 2005 11:02 am    Post subject: Reply with quote
you can do it either way, but I normally removed the top line and just loosened the bottom line,
I found it was easier to NOT loose the crush rings if I removed the bolt once it was in my hand
3 928s,
IXLOR8
PostPosted: Mon Sep 05, 2005 11:06 am    Post subject: Thanks for you help. Reply with quote
Thanks for you help again. I should get the WUR tomorrow.
Wisconsin
timstar92404
PostPosted: Mon Sep 05, 2005 5:28 pm    Post subject: Reply with quote
I was also looking in Haynes and I couldn't find much info on the wur or how to test it.
I thought my low iddling problem during warm up might be due to the wur so I want to know how you can test it.
new wurs are pretty expensive around 240 U.S so I don't want to guess mine is bad.
78 924 sold.
85.5 944
IXLOR8
PostPosted: Mon Sep 05, 2005 9:23 pm    Post subject: WUR Reply with quote
Check out the following Website:
www.rockauto.com
WUR - Beck Arnley == $70.79 with 17.00 core charge. Rebuilt
I also purchased fuel injectors. Beck Arnley $38.79 Each.
Rock Auto has all items shipped dirctly from Factory Warehouse points. They will send e-mails about your order, and you can check your tracking of the order.
One thing to keep in mind, a 30 year old Porsche parts are not keep in any real quanitities at warehouses. I order the WUR on Saturday and it should arrive today Monday. The warehouse only had one unit.
I have been real happy with Beck Arnley parts. They just fit right.
All amounts are US Dollars.
Wisconsin
D Hook
PostPosted: Tue Sep 06, 2005 12:24 am    Post subject: Reply with quote
Only reliable way is to use the pressure gauges and carry out the tests per the Haynes manual. As Lizard pointed out, they don't seem to lend themselves to being rebuilt by the average DIY'er. Maybe someone has had success and would like to share the info?
You can find less expensive WUR's out there, just have to look. Beck-Arnley and Echlin make them also and sell through NAPAOnline.com.
Removing the coil makes the job 10 times easier. No need to remove the wires to the coil, just slide it out and set it ontop of the R2D2 cover. Takes about 20 minutes to R&R. You want to unscrew your fuel filler cap on the gas tank to relieve any pressure in the tank. I forgot to do that and had fuel running out of the return line at a pretty good rate. Take a look at the fuel schematic in the Haynes to identify which is which.
Also disconnect the battery when doing this, since you'll have raw gas/fumes around in the coil area. Let it evaporate before reattaching the cables.
'80 924 n/a SOLD
PostPosted: Tue Sep 06, 2005 1:05 am    Post subject: Reply with quote
...and don't smoke!
PostPosted: Tue Sep 06, 2005 2:15 am    Post subject: Reply with quote
I've had too many bad experiences with Beck-Arnley parts, would never buy them again, especially not for a WUR. JMO.
IXLOR8
PostPosted: Tue Sep 06, 2005 9:10 am    Post subject: WUR Reply with quote
I had great success with replacing the WUR on my 77 924. The car starts up after running - engine warm, the idle has smooth out, lots more power.
Thanks for your help!
Wisconsin
D Hook
PostPosted: Tue Sep 06, 2005 9:43 pm    Post subject: Reply with quote
Please post back if you have problems with the Beck Arnley part. I've heard the same as Vaughan and am curious now. If you don't have a problem, it would be a good source for the WUR for others.
'80 924 n/a SOLD
