sleepy
Posted: Mon Sep 05, 2005 7:06 am Post subject: coolant level |
I'm wondering if i should be worried about my cars cooling system. the main reason is that i can remove the coolant filler cap straight after using the car without boiling water pissing out! There's a small hiss & the water is boiling hot but it hardly raises at all, - I'v never know a car you can do this with?
also, i havn't needed to top up the coolant all summer -it just hasn't lost any?
the fan does come on a hell of a lot on this car but i'm assured thats completely normal. The temp guage has never gone over a quarter way since i got her a year ago so i can't tell anything from that.
Should i be worried??
cheers
-sleepy _________________ meteor silver 1981 924 lux. -UK |
tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Mon Sep 05, 2005 7:33 am Post subject: |
Sounds like maybe the reservior cap isn't holding pressure. If you really want to find out if there's any pressure in there, *carefully* remove the bleed plug after driving for a while & you should definitely get a good spurt out, just watch your face! At just a few bucks, the caps are cheap enough that you can just buy one to try it out. _________________ TJ
Silver '82 924 NA 5-Speed Manual |
Posted: Mon Sep 05, 2005 10:44 am Post subject: |
You should be happy, someone probably already installed a lower temp thermostat and fan switch. _________________ White 87 924S "Ghost"
D Hook
Posted: Tue Sep 06, 2005 12:34 am Post subject: |
I have the low temp fan switch and thermostat and mine barely gets over the 1/4 mark when the fans kick on. Doesn't lose or use coolant.
Still wouldn't hurt to replace the cap. Cheap insurance. _________________ '80 924 n/a SOLD |
Modoc
Joined: 22 Dec 2004 Posts: 155 Location: Rexburg, Id / Fremont, Ca
Posted: Tue Sep 06, 2005 12:49 am Post subject: |
How much does one of these low temp fan switch and thermostat kit type thingys cost? Im interested. _________________ Proud owner of
'88 924s - Sold
'01 ML430
'97 Honda Civic |
D Hook
Posted: Tue Sep 06, 2005 2:49 am Post subject: |
Not sure about the thermostat for the 924S engine but the thermoswitch in the radiator is easily purchased from the major supply houses like Tweeks or Perf. Products. Not sure of the pricing though. _________________ '80 924 n/a SOLD |
Posted: Tue Sep 06, 2005 4:20 am Post subject: |
| Autozone and Advance Auto have themostats for less than $10. |
WhoDak
Posted: Tue Sep 06, 2005 4:22 am Post subject: |
Mines got the lower temp thermostat and fan regulator on it. Amazing, the fan runs a lot, and even when it's 50 degrees outside at night, when I come home it runs for 20 seconds or so after I turn it off. The fan kicks on right when the needle gets past the white section of the temp gauge below 1/4th. _________________ Mike
'82 924 N/A
'91 Toyota Pickup SR5 4x4 Xtra cab |
