The Story So Far
Goto page Previous  1, 2, 3, 4  Next
cleethorpes
PostPosted: Tue Jul 26, 2005 7:18 pm    Post subject: Reply with quote
Bass, heres what tweeks say about it: (at the bottom it details constant running)
About this product
The revolutionary and innovative EBP electric water pump represents a great advancement in automotive cooling management, It has been designed predominantly to increase power and improve cooling efficiency by replacing the mechanically driven water pump. This lightweight and compact unit is far more efficient than traditional pumps, and as such helps to release wasted power and tailors the flow of coolant more accurately to the engine's needs. The EBP has the following benefits: Increase engine power and torque. Better control of engine temperature, reduces coolant volume. Increase in cooling capacity, reduce radiator size, increase in maximum engine speed, improves fuel economy, extends engine life. No impeller or axle 'drag'. Flexible options for pump control. Lighter than standard pump. Compact design, 2 year guarantee. Easy to fit. Supplied with selection of fittings and full fitting instructions. The EBP runs at a speed independent to that of the engine, and is designed to be fitted as low as possible in the coolant circuit to maximise gravity feed and prevent air entering the pump. Designed for universal fitment, the pump can be mounted in several different configurations. Voltage: 9V-15V DC, Max Current: 1.3A, Flow: 13.3L/min (176 gall/hr), Op. temp: -40 to 135ÿ¿ÿ°, Pump Design: Clockwise centrifugal, Motor Life: 15,000 hours, Weight: 260 grams, Dimensions: 70x48mm body, 12-20mm in/outlet, Drive: Magnetic - no shaft seal. This makes the EBP ideal for water cooled motorcycle engines and also sidecar outfits. Wire the pump direct to the ignition for maximum cooling and continuous running - requires removal of the thermostat and mechanical pump impeller.
Simon, do the pumps come with clamps etc for attaching to the car, or is it purely a variety of different pipe fittings supplied?
'24 turbo with dodgy gt bodykit......needs a new home
simsport
PostPosted: Wed Jul 27, 2005 5:13 am    Post subject: Pump Reply with quote
The pump comes with the required pipe stubs to fit. If you cut the bottom hose it will squeez in fine.
I would get the new version with higher flow rate.
I run the pump continuously. I did use the control box but it failed after 2 years of use. The pump is still fine though.
I am after the higher rate pump myself...just need the cash!
Cheers
Simon
Blown is always best!
bass gt
PostPosted: Wed Jul 27, 2005 5:25 pm    Post subject: Reply with quote
Cheers for that Simon. One more question. Does the coolant flow into or out of the bottom hose??
Steve
bass gt
PostPosted: Fri Sep 02, 2005 8:42 pm    Post subject: Reply with quote
Gents,
just to give you a taste of whats been going on. So say the least, we have been VERY busy, but as you will see, i think she looks STUNNING!!!
Still lots to do, like 944g/box with LSD and race suspension, but it's getting there!!
Regards,
Steve
cleethorpes
PostPosted: Fri Sep 02, 2005 10:18 pm    Post subject: Reply with quote
looks really good bass, what colour did you opt for in the end...looks kinda continental to me!
Got quite a few bits to fit now, spa gauges, gts headlight buckets, fia switch, boost controller, fuchs alloys (not exactly hard to fit but at least I have some now!) to name but a few. F/g bonnet and seat should be here soon so I'll have my work cut out after my holidays blending the fg buckets, bonnet, brake cooling pipes etc. Like the splitter and the spoiler.....you really ARE up for the fight then.
bass gt
PostPosted: Sat Sep 03, 2005 9:18 am    Post subject: Reply with quote
http://public.fotki.com/BassGT/931/
Ooops, forgot the link!!
simsport
PostPosted: Sun Sep 04, 2005 1:52 am    Post subject: Very Pretty Reply with quote
The car is a credit to you, looks fast , very well sorted.
From expereince you might think about the font splitter and see if you cant make it such that an off that bends the splitter doesn't require the whole front air dam to be replaced.
From the photo the splitter looks riveted to the air dam...is it?
If so bolts would allow you to replace it. A few of the venues we do are bit unforgiving when it comes to grass trips!
Are the wheels 16"?
I was talking to Porscheshop at Brands and they reckon the boxter caliper kit will fit 15", although I do think my wheels are getting a bit shot now.
According to the written report Ian McMath the 914/6 guy was 'under the weather'.....rats, thought I'd beaten a quick one on a good day!!
Cheers
Simon
WEASEL149
PostPosted: Sun Sep 04, 2005 4:39 am    Post subject: Re: Very Pretty Reply with quote
simsport wrote:
Are the wheels 16"?
I bought the mounting adaptors from Porscheshop and fitted Boxster calipers under 16" Fuchs on my 931. There isn't much clearance from memory but I'll check for you - 15" will probably mean fag paper clearance if they fit.
I was a bit disappointed at Brands - I only spotted 2 931's and one was a race car! I wonder if many will turn up at Reading for the anniversary? It seems they're getting quite rare now.
WEASEL149
PostPosted: Sun Sep 04, 2005 4:43 am    Post subject: Reply with quote
hey Bass Gt, your car is looking very very nice. The mods and work look very professional and the colour scheme is perfect.
bass gt
PostPosted: Sun Sep 04, 2005 6:31 am    Post subject: Reply with quote
Simon,
First off, congrats at the Porsche Festival. Whether the 914/6 was out of sorts or not, a win is a win.
Re the front splitter. Nope, it's bolted in place, so it should minimise the damage when i take to the scenery.
The wheels are 16" and fit a treat. Fronts are 7's and the rears are 9's. Seem to fill the arches nicely.
Off on Monday to get a new exhaust fitted, then try and sort out the oil breather. Spoke to Demon tweeks and it seems the 110 litre water pump, although listed is not available. They included it as the maker assured them of the delivery, yet 18 months later, still no sign of them. So i've ordered up the 80 litre unit. Just got to get the water pump back from the fabricators.
Regards,
Steve
simsport
PostPosted: Sun Sep 04, 2005 8:33 am    Post subject: Tyres Reply with quote
Steve
Thanks, it was nice to win, next up is getting the old girl to go as well up the hills!
Regarding wheels and tyres...wait before buying any tyres as I am awaiting a chat with the club about tyres for next year. Not sure what if anything might change but best not to shell out for a set just yet unless you plan an outing for the final round at longleat. In that case I may have a set you can get away with spare.
Cheers
Simon
PostPosted: Sun Sep 04, 2005 10:06 am    Post subject: Reply with quote
I checked out the bright red and the stance looks sharp.
macBdog
PostPosted: Sun Sep 04, 2005 8:33 pm    Post subject: Reply with quote
Could you post some hi res pics of the car post-paint job? Id love to use them as wallpaper. Youve done such a great job, the car is HOT!
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
bass gt
PostPosted: Sun Sep 04, 2005 9:11 pm    Post subject: Reply with quote
Mac,
I'd love to post them. Only I'm not sure how!! If someone could give me a pointer.....
J1NX3D
PostPosted: Mon Sep 05, 2005 10:21 am    Post subject: Reply with quote
put your link between [img ] and [/img ] but dont leave a gap between the 'g' and ']' like i have
like so
quote this post and it will show the format for posting pics
'86 944
Page 3 of 4
