juno
Joined: 28 Apr 2004 Posts: 200 Location: Up North, United Kingdom
Posted: Thu Sep 01, 2005 10:30 pm Post subject: Something missing from my car? |
I can see right underneath the bonnet of my car at the bottom of the windscreen, through to where the battery is. Also in heavy rain, water collects in the battery well and opposite and on top of the engine. Should there be a guard here to stop this? _________________ 1980 924 Turbo RHD. 3" > 2.5" Stainless straight-through exhaust. |
skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Posted: Thu Sep 01, 2005 11:09 pm Post subject: Re: Something missing from my car? |
| juno wrote: | | I can see right underneath the bonnet of my car at the bottom of the windscreen, through to where the battery is. Also in heavy rain, water collects in the battery well and opposite and on top of the engine. Should there be a guard here to stop this? | there should be drain holes there to let the water out - probably clogged. _________________ 924.org (no time to complete)
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
Chrenan
Posted: Fri Sep 02, 2005 12:03 am Post subject: |
| Quote: | | I can see right underneath the bonnet of my car at the bottom of the windscreen, through to where the battery is. |
This is the way the 924 is designed.
There should be drain holes as the front of your battery tray/box. They are covered with rubber flaps which sometimes stick, or, as suggested, they may be filled with gunk. _________________ 1987 951 - M193 Version for Japan |
Posted: Fri Sep 02, 2005 8:42 am Post subject: |
the only p-car that I am aware that they did this on is the 928, and they still had drain holes underneith, and guess what,
they still got plugged _________________ 3 928s, |
