Bilsteins Installed - UPDATED with anti-roll bar information
Chrenan
PostPosted: Thu Sep 01, 2005 3:45 am    Post subject: Bilsteins Installed - UPDATED with anti-roll bar information Reply with quote
Well, installation of the Bilsteins went well on the weekend, everything is done, new shocks on all 4 corners, new control arms (seam welded) and bushings and and ball joints and tie rods and tie rod ends and wheel bearings etc etc etc. Basically wanted to hit as much as I could while I was in there.
Got the alignment done, and it drives very nicely. Quite stiff compared to the old worn out shocks (KYB's on the rear which were pretty useless). At slow speeds it is pretty choppy with the Bilsteins, but once the speed picks up a touch, it is very, very nice - so solid and stiff. Still early going, but I am very happy so far.
Gram
PostPosted: Thu Sep 01, 2005 5:03 am    Post subject: Reply with quote
Sounds good..what model Bilsteins..?
'82 924 NA Euro (hers)
'98 Audi A4 TDI (ours)
PostPosted: Thu Sep 01, 2005 6:26 am    Post subject: Reply with quote
Hey Chrenan,
did you put some atf in there with the bilsteins or did they say not to? or is it just for some brands of shocks that you do that with?
3 928s,
Chrenan
PostPosted: Thu Sep 01, 2005 6:55 am    Post subject: Reply with quote
The shocks are green on the back, and yellow with blue dust cover on the front.
Didn't add any ATF as the instructions that came with the shocks didn't say to, when in doubt follow what the manufacturer says I suppose...
PostPosted: Thu Sep 01, 2005 7:14 am    Post subject: Reply with quote
agreed on that, I just wish that there was a standard on that.
3 928s,
augidog
PostPosted: Thu Sep 01, 2005 9:16 am    Post subject: Reply with quote
It's funny; I'm doing the same thing this week but putting in KYB's
I just finished the front left. I had a bent stabilizer arm so I pounded it straight and did some new rubbers at their connection and a new ball joint. I also cleaned the arm off and threw on some new paint.It's funny how much better you feel about the repair if its clean and painted. It sits much higher now and I can really tell the difference in just the stationary bounce from right to left side.
I tell you I saved a lot of time and took the shock and strut down the road to a garage for replacement. I would highly recommend it. I started to mess with all the rented spring compressors and pipe wrenches and seized nuts and said forget it.
It was the best $35.00 I spent in a while. Tomorrow is the other side and rears.
I can't wait to road test.
Any hints about removing the rear shocks? It seems ez enough.
PostPosted: Thu Sep 01, 2005 10:09 am    Post subject: Reply with quote
the rears are easy, just make sure you have a jack to get some weight off the rear
3 928s,
CBass
PostPosted: Thu Sep 01, 2005 3:16 pm    Post subject: Reply with quote
So what's the trick to making the rear shock install removal easy? Jack the car with the wheels still on the ground or what?
Chrenan
PostPosted: Thu Sep 01, 2005 11:58 pm    Post subject: Reply with quote
Here's what I did for the rears. Leave the wheels on, jack up the rear of the car and use a jack stand under each torsion bar extension (that thing sticking out just in front of the rear wheels). Now you've got the rear wheels dangling off the ground. Apply the parking break, place your jack under one of the rear tires and raise the jack so it just takes the weight of the wheel. Now, you basically have the shock fully extended and everything supported, so when you remove the bolts at the top and the bottom nothing will shift. Remove the bolts and you should be able to compress the old shock by hand to manouver it out of place. Then, compress the new shock by hand (harder than with the old shock, but doable with some grunt). Quickly get the compressed new shock under the car and get it into the upper mount and slip the bolt into place. As the new shock slowly expands, it will line up with the bottom hole if you guide it correctly. Slip the bottom bolt through, torque the upper and lower nuts (maybe with some loctite) and you're done. Should take an hour to do both sides if you are slow and careful like me...
CBass
PostPosted: Fri Sep 02, 2005 12:33 am    Post subject: Reply with quote
That's pretty much what I did, but it was still a PITA on my car no matter how I jacked the wheel.
PostPosted: Fri Sep 02, 2005 8:38 am    Post subject: Reply with quote
I just jacked it up in the same spot as stated and then pulled the tire off, and you kind of have to play the jack under the shock support to find just the right height for the bolt to slide out
3 928s,
tj924
PostPosted: Fri Sep 02, 2005 10:35 am    Post subject: Reply with quote
I gather then that the rear is easier than the front because you don't need a spring compressor like you do with the front?
TJ
PostPosted: Fri Sep 02, 2005 11:13 am    Post subject: Reply with quote
Correct tj
3 928s,
Chrenan
PostPosted: Fri Sep 02, 2005 11:55 pm    Post subject: Reply with quote
The front is definitely a little more involved, but not too hard, just more time consuming.
PostPosted: Sat Sep 03, 2005 1:29 pm    Post subject: Reply with quote
Right on way to go.
