augidog
Posted: Sun Aug 28, 2005 11:28 am Post subject: Exhaust manifold gasket fix 78 NA, should I try it? |
Should I go for it or leave it for a muffler guy? I'm on vacation this week. _________________ 1978 924 95 mile daily driver.
Posted: Sun Aug 28, 2005 11:36 am Post subject: |
depends on how much money you have.
Those nuts can be a real pain to get off and most guys will just lean on them until the stud snaps then the bill just went up by a couple of hundred.
If you take your time and use plenty of penetrating oil it's not that hard. _________________ 1979 924 (Gone to a better place)
CBass
Posted: Sun Aug 28, 2005 5:39 pm Post subject: |
Patience is the key here, that and a couple cans of liquid wrench. Be sure to give the nuts a good brushing with a wire brush before soaking, and between soaks. _________________ '81 931 in various states of assembly |
Posted: Mon Aug 29, 2005 9:21 am Post subject: |
I would say go for it, just make sure that you buy all new replacement nuts (the copper locking style) and all new exhaust studs, as well as having a M8x1.25 tap to clean the holes out, and possibly a helicoil handy, as well as remembering to use neversieze/antisieze on the part of the exhaust stud which is not covered, and possibly on the part that goes into the head (however I found mine tended to back out if I used it here) _________________ 3 928s, |
augidog
Posted: Mon Aug 29, 2005 11:10 am Post subject: |
I'm going to Napa tomorrow for the bolts and manifold gasket.
I've read I can just ask for the VW replacement manifold bolts .
Is there a year that will work in-case this guy panics? _________________ 1978 924 95 mile daily driver.
Posted: Mon Aug 29, 2005 11:40 am Post subject: |
just say 1.8L 1983 VW rabbit, the studs and nuts are exactly the same, and as I said replace them all, or at least I would _________________ 3 928s, |
