fuse diagram
ATL_racer
PostPosted: Thu Aug 25, 2005 5:00 am    Post subject: fuse diagram Reply with quote
I have a late 1979 2.0l NA 924. I have a haynes manual but it seems only to have a diagram with the relays labeled, not the fuses. The owner before me put american fuses in some of the slots....and i need to know what "size" fuse goes to replace them,
also the fuse i believe to be the one for the power windows keeps blowing... i replace it with the same size and it blows, so i would like to rplace all the fuses( they are dirt cheap) with the correct ones.
so if anyone has a labeled fuse diagram that would be great...
Thanx in advance
late 1979 porche 924, red 2.0l NA 5speed snailshell
Plans: Restore exterior, revitalize interior, install killer sound system, run engine in stock form and have fun.(+ a short throw shifter if i can find one)
Benino
PostPosted: Thu Aug 25, 2005 5:09 am    Post subject: Reply with quote
I think this information is in the manual. (the one that came with the car from Porsche). I'll try to remember to take a look at mine when I get home in case you don’t have one.
on the power windows thing, I had a problem like you are describing and it turned out the rubber boot that protects the wires that go from the car into the door was not holding up and the wires were being cut by the metal of the door and shorting out there.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
PostPosted: Thu Aug 25, 2005 7:12 am    Post subject: Reply with quote
The fuses and relays changed slightly during production, and I don't know exactly which year. Also, there was some variation between US and ROW models. The photo at right shows the 15 main fuses and the bottom row of relays. White fuses are 8-Amp, Pink/Red=16-Amp, Blue=25-Amp
Listed below is how my car is set up:
· Main fuse panel
1. Headlight, Left, Low Beam (8 Amp)
2. Headlight, Left, High Beam (8 Amp)
3. Headlight, Right, Low Beam (8 Amp)
4. Headlight, Right, High Beam (8 Amp)
5. Fog Lights (16 Amp)
6. Brake lights, Courtesy light, Engine compartment light(8 Amp)
7. Emergency Flashers, Lighter, Clock (8 Amp)
8. Blinkers(8 Amp)
9. Parking lights, mirrors (8 Amp)
10. Heater/Vent Blower Motor (16 Amp)
11. Windshield Wipers (8 Amp)
12. Cargo Area Light, License Plate Lights, Ashtray (8 Amp)
13. Side Markers, Left (8 Amp)
14. Side Markers, Right (8 Amp)
15. Fog lights (16 Amp)
· Auxillary panel (1979 & later) - (not pictured)
1. Horn (8 Amp)
2. Fuel Pump (16 Amp)
3. Radiator Fans (16 Amp)
4. Rear Window Defogger (25 Amp)
5. (Empty - Air Conditioner Fan) (16 Amp)
6. (Empty - Air Conditioner Controls) (25 Amp)
7. Empty
8. Power Windows (25 Amp)
9. Empty
Benino
PostPosted: Thu Aug 25, 2005 12:05 pm    Post subject: Reply with quote
looks like ozzie posted everything. I took pictures of the manual for 1977 and 1980 turbo that I have so I might as well post them just for fun.
1977:
1980 turbo:
BillA
PostPosted: Sat Aug 27, 2005 6:29 pm    Post subject: Fuse Chart Reply with quote
Does anyone have one for a 78 or is it similar to the 78?
ED.
PostPosted: Sat Aug 27, 2005 11:30 pm    Post subject: fuse chart Reply with quote
Does any one know if the 1980 turbo chart is the same as a 1981 NA chart? I also do not have a chart for my car.
Benino
PostPosted: Sun Aug 28, 2005 12:00 pm    Post subject: Reply with quote
those are the only two books I have and I don’t know for sure if they are the same as yours but you can just remove your fuses one at a time to verify. Once you know, I'm sure the rating of the fuses will be the same. I've used 8amp fuses when a 16 is the one that should be used and they don’t burn out. Maybe after a long period of time but definitely not soon.
PostPosted: Mon Aug 29, 2005 10:26 am    Post subject: Reply with quote
for the most part the wiring between the 80 turbo and the 80 NA will be the same, however the main differences that I can think of is the fuel pump relay will be different, and will have an extra wire in the engine bay to ground out the fuel pump to an overboost cutoff switch, as well the ICM has a different pin out.
3 928s,
