1979 head to 82
pyromjm
PostPosted: Sat Aug 27, 2005 7:06 am    Post subject: 1979 head to 82 Reply with quote
My friend gave me his 79 924 n/a for use as a parts car for my 1982 924 n/a. I know his head has had some work done on it and is probably in much better condition than mine, is it going to be a compatable swap to my later car? Also, what else isnt going to be a compatable swap?
thanks,
-Mike
1982 924 NA gray/silver with black int.
Chrenan
PostPosted: Sat Aug 27, 2005 8:01 am    Post subject: Reply with quote
Yes, head is a compatible swap for all 1976-1982 normaly aspirated cars.
pyromjm
PostPosted: Sat Aug 27, 2005 12:57 pm    Post subject: Reply with quote
Thanks Chrenan Do you or does anyone else have any tips that has done headwork or head swap before that wouldnt show up in say a haynes manual or something? Thanks a lot,
mike
AppleBit
PostPosted: Sat Aug 27, 2005 2:26 pm    Post subject: Reply with quote
you will notice on the earlier heads there are exhaust holes that come out on the intake side of the head- just plug these up with bolts to keep the intake running cool.
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
CBass
PostPosted: Sat Aug 27, 2005 4:02 pm    Post subject: Reply with quote
Port match everything, clean up all the welds in the downpipe with a grinder, chase all the threads, and check to make sure the head is flat...
A really good idea would be to disassemble the head, and send it to a shop for a bit of mild porting work. Best money you can spend on getting more out of these engines.
PostPosted: Sun Aug 28, 2005 4:21 am    Post subject: Reply with quote
one suggestion that I have is if it isnt broken DONT mess with it, unless you have blown your headgasket dont remove your head, leave it and keep the other as a spare, you will need to have the timing set after and a torque wrench and you wont see any improvement really.
3 928s,
PostPosted: Sun Aug 28, 2005 7:00 am    Post subject: Reply with quote
The middle production models like the 79 have a tendency to crack. Most all normally aspired 924 heads use the same valve size, the exception being some of the very early 77 engines, which may have come with bigger valves. There is a difference in the exhaust port shape over the years, but I prefer the late model head over the earlier.
If your 82 cylinder head isn't damaged and unrepairable, why replace it?
As Lizard already stated, "if it ain't broke, don't fix it!".
pyromjm
PostPosted: Mon Aug 29, 2005 11:20 am    Post subject: Reply with quote
thanks for the input guys.
The spare head from the 79 has been ported and polished already and i figured it would be cheaper to put it on instead of having my head ported and polished. I really do want to take the head off and rebuild everything for educational purposes and to quiet down the engine which is REALLY noisy and squeaky.
-Mike
