AGD931
Joined: 17 Mar 2003 Posts: 289 Location: Athens, Greece
Posted: Tue Aug 16, 2005 12:32 am Post subject: Front fog lights |
Does anyone have factory fitted foglights under the front bumper? Rare option I know.
If so, I would appreciate some pics of the lights themselves and of the mounting brackets
Many thanks.
Arthur _________________ 1981 931 S2
1990 E30 320i Cabrio
1979 Ford Capri Ghia |
WhoDak
Posted: Tue Aug 16, 2005 1:15 am Post subject: |
I'd like to know how they work too. Are they worth having on there? Do they really help vision at night or are they not needed that much? _________________ Mike
'82 924 N/A
'91 Toyota Pickup SR5 4x4 Xtra cab |
Posted: Tue Aug 16, 2005 2:15 am Post subject: |
I have only ever seen them on the US models as the euro models have them built into the bumper,
imo they really dont look all that great, however all the US bumpers I have seen already had the mounting hole in them, and you can install any foglight you do so desire. and light technology has come along way in the past few years _________________ 3 928s, |
skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Posted: Tue Aug 16, 2005 3:03 am Post subject: |
actually I do . . . I have the sales slip from the dealership showing them as a factory option:
http://www.lirdies.com/924/images/before/000_0867.jpg
Do you need mroe information or images? _________________ 924.org (no time to complete)
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
AGD931
Posted: Tue Aug 16, 2005 3:18 am Post subject: |
The lights mounted in the front bumper on Euro cars are driving lights that come on simultaneously with high beam and are also used for flashing the headlights when the pods are down.
Porsche used to provide an installation kit (477 941 903A) for fitting under bumper fog lamps to Euro cars. This included the lamps/brackets/2stage switch for activation(left of cig lighter)/wiring loom. Of course this kit is NLA. however as I am looking at fitting fog lights, I would like to do it "properly" making sure that the lamp assemblies are at least shaped similarly to the originals and which I suspect were Hella/Bosch
On the Euro cars, they were not mounted under the bumper but on the lower front panel which has the holes pre-drilled
Fog lights are useful at night on roads without street lightning as they light up the edge of the road, very common here....
EDIT - As I was writing the message "skemcin" posted... I would appreciate more info and images
Thanks _________________ 1981 931 S2
Posted: Tue Aug 16, 2005 4:15 am Post subject: |
Good foglights can be very helpful when it's actually foggy, and even more useful when aimed as cornering lights (sornering lights are aimed slightly outwards so you can see more of the ground to the outside of where you are is aimed).
924s have the basic wiring connections already in the main harness under the dashboard, so adding foglights is fairly easier if you have the factory assembled plug-in underdash harness (still fairly easy without).
The plug-in harness has the plug for the factory foglight switch (a 77-84 VW Rabbit/Jetta part), fuse holder, relay socket, and the connects to the main wiring harness. If the foglight harness is still available (it was less than $20 when I bought mine), I would suggest trying to buy it as a starting point, then you can use whichever foglights you want.
A hot wire is already under the hood, waiting for connection to the foglights by the brake vacuum booster where the main wiring harness comes out of the firewall.
Under the hood, you mount the foglights to the bumpers in the predrilled holes, and run the hot wire to the lights, and a ground wire over to the main ground location in the left front corner.
I wrote an article on foglight installation that was submitted to PCA PANORAMA a long time ago. Don't know if it was ever published, but it would have been after the magazine article that I wrote that was published that detailed how to install and troubleshoot the rear window wiper (fifteen years ago?). |
skemcin
Posted: Tue Aug 16, 2005 4:20 am Post subject: |
| AGD931 wrote: | . . .
Thanks | lol - timing is everything.
My car is in the shop for paint but I will be checking in on it either tomorrow or Wednesday evening. I'll be happy to take some pictures and notes on the assembly that I have. The picture I have linked here:
http://www.lirdies.com/924/images/before/000_0882.jpg
shows the location of the fog lamp switch (as I recall). It sis the left/right toggle switch to the left of the cigerrete lighter (just above the heater control sliders).
I took this picture over a year ago and my interior is gutted right not - but I am pretty sure that was the location of the switch.
I'll scan the dealer BOS to make sure it is factory added and not dealer - I can't for certain remember which it is - something tells me it was factory.
And they are Bosch lamps - 55w bulbs.
EDIT: This picture confirms that I was correct about the location of the fog light switch:
http://www.lirdies.com/924/images/before/000_0881.jpg
You can see the icon on the toggle switch in the lower right hand corner of the image.
Hope all this helps. _________________ 924.org (no time to complete)
AGD931
Posted: Tue Aug 16, 2005 4:51 pm Post subject: |
Skemcin,
Great info, thanks very much.
Will try to track down the wire harness and stuff, to ease the job.
skemcin
Posted: Wed Aug 17, 2005 12:16 pm Post subject: |
OK, I went through my vehicle documentation, and the receipt from the original delivery shows the following as dealer add-ons:
Rust Proofing (Rusty Jones)
Polybond
Stop-a-flat
CR 2000 Cassette Stereo
Cruise Control
Fog Lamps
So, these are dealer installed Bosch Fog Lamps "FO SHO"!
I'll try to get pictures of the mounting tomorrow or Thursday night. _________________ 924.org (no time to complete)
