924 1988 died while driving what should i do now?
mantise
PostPosted: Mon Aug 01, 2005 9:27 am    Post subject: 924 1988 died while driving what should i do now? Reply with quote
hi i have a little problem. i was driving to the gym and my car just died on. it didn't shake or nothing but just turned off. after that i couldn't get the car started. the car doesn't turn on any more it just makes the click sound. there is no problem with the battery or alternator. i went to the machenic and he manually tried to crank it and it wouldn't crank like the engine is stuck. there is oil in the car and it is has been changed not to long ago. i'm really not sure what to do so any help would really be appreciated. can any1 help me with any suggestions to bring my car back to life i really mis it. thanks in advance guys
timstar92404
PostPosted: Mon Aug 01, 2005 9:47 am    Post subject: Reply with quote
did you check to see if the timing belt hasn't broken off or come loose?
hopefully it didn't... as it would cause engine damage.
if it just clicks sounds like your starter is bad mine won't crank sometimes it just goes "click" my mechanic said the starter was bad..
78 924 sold.
85.5 944
skemcin
PostPosted: Mon Aug 01, 2005 10:04 am    Post subject: Reply with quote
gas?
924.org (no time to complete)
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power
PORSCHEV
PostPosted: Mon Aug 01, 2005 11:05 am    Post subject: Reply with quote
If it cranks with a different sound than usual... it is the timing belt. That would be my first guess with out even looking at it.
1978-#53 "D" track racer.
mantise
PostPosted: Mon Aug 01, 2005 12:18 pm    Post subject: Reply with quote
the timing belt is not broken or loose the car does have gas in it. anyway js there a way i could check if it is the starter.
timstar92404
PostPosted: Mon Aug 01, 2005 6:10 pm    Post subject: Reply with quote
well can't you hear the starter turning if you can't then it isn't working.
does your battery have enough power?
78 924 sold.
85.5 944
PostPosted: Mon Aug 01, 2005 6:30 pm    Post subject: Reply with quote
When you say your mechanic manually cranked the motor and couldn't, what exactly did he do?
When it died, was the engine still turning over while in gear?
Basically trying to get a handle on whether we're talking a siezed engine or electrical/ignition/valve timing.
Total failure like that is more likely to be in the electrical/ignition category like a wire just gave up.
Vince Ponz
PostPosted: Tue Aug 02, 2005 6:54 am    Post subject: Reply with quote
Common fault with these cars. I think it is the speed sensor? It is the piece that has a pickup on the crank. If it is faulty the car will not start.
Almost against the firewall there are four wires meeting above the motor.
Jiggle it and it may start. I had this problem with my 88 924
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
Vince Ponz
79 931 Euro stock
88 924S SE
87 911 Targa stock
mantise
PostPosted: Wed Aug 03, 2005 5:44 am    Post subject: Reply with quote
the mechanic put a wrench or something that fits on the motor pully and tried to turn it. i went to another mechanic and he said it might be the something damaged under the oil pan becouse i have a crack in the oil pan that leaks out oil slowly. i refill it every 2 days. and he said it he might find something if he removes the oil pan. also vince where exactly do i find those wires beocuse i'm not even sure what a fire wall is. thanks for all your help guys. and yes the battery is also completely charged.
timstar92404
PostPosted: Wed Aug 03, 2005 9:37 am    Post subject: Reply with quote
firewall I'm pretty sure means the metal area behind your dash and at the back of the engine... the whole metal area between the interior of the car and back of engine.
electrical wires come out of here that go to the engine bay.
78 924 sold.
85.5 944
