Stange sound when turning
janne
PostPosted: Thu Jul 28, 2005 11:58 pm    Post subject: Stange sound when turning Reply with quote
Hello,
I recently bought a 1980 924. I've started hearing a low fequenzy noice when I turn the steeringwheel to the right. This is only audiable when I'm driving around 70 km/h and upwards. When I'm driving slowly it sounds fine. I'm also getting some shaking in the steeringwheel at higher speeds.
What wrong with my car? Any ideas?
Chrenan
PostPosted: Fri Jul 29, 2005 12:01 am    Post subject: Reply with quote
Shaking of the steering wheel at higher speeds could be a wheel balance probelm, any tire shop will be able to diagnose.
The low frequency noise when turning, I'm not sure about, more detail around what it sounds like may help.
By the way, the folks here generally like to know where people are from, so you might want to update your profile. There might me a board member in your hometown.
janne
PostPosted: Fri Jul 29, 2005 1:15 am    Post subject: Reply with quote
Thanks for answering. I've updated my profile now.
The sound is a low frequenzy hum that feels in the entire car, and it starts as soon as I turn the wheel just a little bit to the right, and it doesn't get more intense if I turn the wheel more to the right. So, it's like on-or-off.
Chrenan
PostPosted: Fri Jul 29, 2005 1:23 am    Post subject: Reply with quote
Hmmm, OK, with that information someone should be able to come up with some ideas.
Board member "Racing" is from Gothenbrug Sweden and has lots of 924 knowledge, you might want to send him a private message as well.
PostPosted: Fri Jul 29, 2005 1:26 am    Post subject: Reply with quote
I'm suspecting a loose wheel bearing; at least tighten, best to repack and inspect to see if it needs replacement. Jack up each corner, see if the wheel feels loose by wiggling front-to-back and side-to-side by hand.
WhoDak
PostPosted: Fri Jul 29, 2005 1:42 am    Post subject: Reply with quote
Loose lug nuts?
Mike
'82 924 N/A
'91 Toyota Pickup SR5 4x4 Xtra cab
Slam
PostPosted: Fri Jul 29, 2005 6:02 am    Post subject: Reply with quote
Something bent and rubbing in the wheel well?
(Sounds a bit rude, doesn't it?)
I'd check the bearings first - but wouldn't they growl in a L/H turn as well?
janne
PostPosted: Tue Sep 06, 2005 6:37 am    Post subject: Reply with quote
Problem solved!
It was the wheel bearings that were bad. I changed both of them on the left front wheel, and now everything works and sounds perfect.
Thanks everyone
Vince Ponz
PostPosted: Tue Sep 06, 2005 6:41 am    Post subject: Reply with quote
Another solution would be to stop turning.
I thought for a moment it was a power steering problem with fluid being low.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Tue Sep 06, 2005 10:52 am    Post subject: Reply with quote
I like vinces idea the best,
3 928s,
PostPosted: Tue Sep 06, 2005 4:49 pm    Post subject: Reply with quote
These cars were made for turning!
PostPosted: Tue Sep 06, 2005 5:23 pm    Post subject: Reply with quote
I am just about to change my rotors and replacing the bearings at the same time.
I just wish the bearing mob would give me the right ones. They keep giving me the ones for the turbo.
janne
PostPosted: Tue Sep 06, 2005 11:52 pm    Post subject: Reply with quote
I used the same bearings that VW use on most older models ie. front wheel bearings for WV beetle.
Slam
PostPosted: Wed Sep 07, 2005 6:06 am    Post subject: Reply with quote
You might want to do the right bearings as well. It's best to do both sides at the same time. You might find the right ones fairly close behind in wear. Jack up the car and grab the front wheel at the top and bottom, then push and pull the wheel. Any click indicates the bearing's on its way out. Side to side checking won't tell you enough about the bearing.
That said, for some reason my 944 seems to wear out l/f bearings faster than r/f.
PostPosted: Wed Sep 07, 2005 7:27 am    Post subject: Reply with quote
Hey Ozzie, I have new inner and outter wheel bearings for a 4 bolt setup sitting at home, and would be willing to sell them cheaper than you would be able to get them for even with shipping. make me an offer in a PM
3 928s,
