Rooy
Posted: Sat Jul 16, 2005 2:46 am Post subject: 924 driveshaft vibration |
Hi guys, I'm trying to track down a nasty vibration coming from the driveshaft in a '78 924. It has a 5 spd trans and driveshaft out of an '82. Believe it is the '016/9' type.
The vibration appeared right after a spirited driving session including a pull to 6k up a hill in 2nd. The vibration is only apparent at revs above 3k, regardless of gear or speed.
I've pinpointed it to the driveshaft itself. With the car at a stop, clutch engaged (pedal up), revving it above 3k produces the vibration. With clutch disengaged, there is no vibration. So it is only happening when the driveshaft is spinning.
I'd appreciate any help in diagnosing this. Thanks!
Andrew
Neenah, WI |
Posted: Sat Jul 16, 2005 8:33 am Post subject: |
Torque tube bearings? _________________ Porsche 924 1984 (UK import) NA
Posted: Sat Jul 16, 2005 9:55 am Post subject: |
nope its the clamping sleeve nasty little piece located in the tranny its the the equivalent to a u-jount in a conventional driveshaft car...they break causeing a bad vibration. its no joy to get to iether.
http://www.924board.org/viewtopic.php?t=8575&highlight=shift+coupler _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
endwrench
Posted: Sat Jul 16, 2005 10:00 am Post subject: |
Yea, think Ozzie has it right. Mine does almost exactly the same thing and I know without a doubt my bearings are going.
Todd
Hmm, just saw Joes response and I have no idea what your talking about but it may be somethng. |
Posted: Sat Jul 16, 2005 10:52 am Post subject: |
its a shift coupler i called it a clamping sleeve lets see what the pet cd calls.
you know it connects the 2 drive shafts ends together to form one..
when my rear wheel bearings went they made alot of noise with the the
balls catching in there races it was terrible. _________________ 1979 porsche 924 Na
Rooy
Posted: Sat Jul 16, 2005 3:36 pm Post subject: |
| Quote: | | http://www.924board.org/viewtopic.php?t=8575&highlight=shift+coupler |
That is exactly my problem Joe. The vibration starts just above 3k then seems to go away or it just smooths out.
The Haynes manual calls it the connecting sleeve.
Guess I will be dropping the tranny. Thanks again...I knew someone else had to have run into a similar failure!
Also, any tips on the removal procedure? Have removed trannys from other cars, just wondering if there are any 'gotchas' on this one. And anything else that I might want to replace while it's out? |
Posted: Sun Jul 17, 2005 3:17 pm Post subject: |
yea happend to me right at 3200 rpm then went away alil under 4 grand
http://images.snapfish.com/34447%3A8723232%7Ffp3%3B%3Dot%3E2329%3D969%3D%3A49%3DXROQDF%3E2323972%3B7%3B4%3A6ot1lsi
heres a pic of where the clamping sleeve is located all you gotta do is
secure the rear end up and then attach a fllor jack to the tranny then loosen it all up including the axels being removed and pull it back after loosening on e end of the sleeve then after its loose on one end youll most likel;y have to rotate the motor a lil to get to the allen bolt on the other end of the claming sleeve then once both ends are loose you can pullthe tranny it back to get out the clamping sleeve this job will give you wonderous rewards and isnt that hard really. Good luck & check out the pic might help you a lil.
leadfoot
Posted: Mon Jul 18, 2005 7:21 pm Post subject: |
Hey Joe the link you supplied to your info on fixing the problem didn't include the pics anymore. If you still have them would you mind posting up a couple, I'd be interested in seeing one of the broken coupler.
thanks
Leadfoot. _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
Rooy
Posted: Tue Jul 19, 2005 3:03 am Post subject: |
| Update: got under and looked at the clamping sleeve through the inspection hole. Looks fine. The welds are still intact. So, I guess it's time to look at the driveshaft bearings. Just need to get my normal daily driver fixed so I can take the 924 off the road for a while. |
Vince Ponz
Posted: Tue Jul 19, 2005 9:00 am Post subject: |
Too bad you are so far away. I have a good torque tube in the garage. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
