timstar92404
Posted: Thu Jul 14, 2005 7:34 pm Post subject: high oil consumption |
I just got an oil change 2 months ago and I don't drive too far, but I drive daily short trips to school and work (less than 20 km).
I have been driving hard though and in stop and go traffic.
when I got the oil change 2 months ago the oil was in the middle of the min/ max and today I checked it and it was below min so I topped it up. it took about 800 ml to get it to go to the middle mark. I would need to add more than a litre to get it to go to the max.
anyways is this normal or is my engine going to need a rebuild soon?
just wondering I thought oil consumption like this usually means your engine is going to blow very soon.
I don't see any major leaks anywhere that I know of. _________________ 78 924 sold.
85.5 944 |
Joined: 04 Dec 2002 Posts: 767 Location: Blyth, Northumberland, UK
Posted: Thu Jul 14, 2005 9:08 pm Post subject: |
Mine hardly uses any oil now but the old engine used to drink the stuff (rings were shot on #4 cylinder) used to make a lovely smoke plume aswell! _________________ Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead. |
John Brown
Posted: Thu Jul 14, 2005 10:41 pm Post subject: |
Top off the oil. Fill it to the max, not the middle. Don't let it go below the min.
How many miles or km did you drive? _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
Neil924
Posted: Fri Jul 15, 2005 2:25 am Post subject: |
| It's your oil, always keep it to the max. Do you see fresh spots of oil in your driveway? |
timstar92404
Posted: Fri Jul 15, 2005 6:18 am Post subject: |
NO I don't see oil on the driveway but I'm not 100% sure. I wanted to put a big piece of cardboard under the engine to see if there are any drips.
I don't drive much my trip odometer is not working so I don't know.
I did drive pretty hard recently and I drive mostly in stop and go traffic just 10-15 min drives to and back from school / school and other short trips. _________________ 78 924 sold.
85.5 944 |
chris24
Joined: 17 Jan 2005 Posts: 334 Location: boston/nottingham UK
Posted: Fri Jul 15, 2005 7:23 am Post subject: |
How flat is your driveway?
Sounds like quite a bit of oil for 800km (20km trips, maybe 40 in 2 months), with no leaks or oil burning. My engine has done big miles and it uses virtually nothing. _________________ 1983 - 924 (185K miles) - not mint
1990 - 944S2 cab (52K miles) |
Posted: Fri Jul 15, 2005 8:59 am Post subject: |
Don't take it as Gospel, but didn't the owners manual quote something like 1 litre per 1000km's (maybe miles?) for oil consumption?
Your consumption doesn't sound ridiculously high to me. Sure, it might be burning some oil but she's 25+ years old, y'know...
Mine doesn't use/burn and oil but I run Mobil 1 and there's no obvious leaks, so that's not surprising. _________________ '80 924 Turbo |
numbbers
Posted: Fri Jul 15, 2005 10:14 am Post subject: |
Well, I just added a quart to my 931 today. It generally uses a quart on every third tank of gas. But, I would expect less oil consumption on an N/A. _________________ 1980 924 Turbo |
D Hook
Posted: Fri Jul 15, 2005 11:08 am Post subject: |
Mine uses more oil around town than on the highway. It might use a quart between changes when most of the driving is in town. After driving over 1000 miles from here to Illinois, it didn't use any. YMMV. _________________ '80 924 n/a SOLD |
augidog
Posted: Fri Jul 15, 2005 11:12 am Post subject: |
I just repaired some leaks but I was an ez quart per week on 1000 miles _________________ 1978 924 95 mile daily driver.
tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Fri Jul 15, 2005 1:04 pm Post subject: |
So at what point should you top it off again (ie when at 1/2 way down, 1/4 way down, 3/4 down etc). At the moment I'm doing probably a couple of hundred km/week & check the oil weekly. _________________ TJ
Silver '82 924 NA 5-Speed Manual |
