turbo woes
jamesi
Guest
PostPosted: Sat Apr 06, 2002 4:54 pm    Post subject: Reply with quote
i have an 82 turbo, was replaced just before bad waterpump ruined my day, and my motor, have another motor now, went to change, took off turbo and checked it to see if it was still good, was hard to turn at first, but took partially apart and cleaned, now it turn kinda easy, can spin it by hand then it turns for additional few seconds, is this good, or should i try to find one to replace it, or just overhaul it.
[ This Message was edited by: jamesi on 2002-04-06 16:55 ]
PostPosted: Wed Apr 10, 2002 1:31 am    Post subject: Reply with quote
That sounds good to me, about what the turbo in my '82 931 was like, put it back in, no issues except earl leaks...
TroyDest
Guest
PostPosted: Wed Apr 10, 2002 4:21 am    Post subject: Reply with quote
Yeah, that sounds good. Check very carefully on the inside of the exhaust half. Most of the ones I've seen lately are cracked inside, some of them really bad. They look perfect from the outside.
