outter tie rods.... (larger images...)
Paul924
PostPosted: Sun Jun 19, 2005 5:59 am    Post subject: outter tie rods.... (larger images...) Reply with quote
ok, so i ordered one complete outter tie rod and one tie rod end (i didnt have the money to get two complete ends, but it is just the one that is bad, the other one is just fine..) and the ends are different, but is it simply a brand thing or should i call paragon products and bitch at them... or would it be safe to install... pictures below to help... i do like the codder pin safty aspect, as to just the nylon insert....
1979 924 NA
Diesel
PostPosted: Sun Jun 19, 2005 6:02 am    Post subject: Reply with quote
Both are safe. I have installed both types on my cars and they are the same.
Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D
Paul924
PostPosted: Sun Jun 19, 2005 7:40 am    Post subject: Reply with quote
one of each side? i would think you need a matching pair?
1979 924 NA
PostPosted: Sun Jun 19, 2005 8:38 am    Post subject: Reply with quote
Threads are different also, the nylon one has a finer thread.
Both should be ok though
numbbers
PostPosted: Sun Jun 19, 2005 9:16 am    Post subject: Reply with quote
They both will work, but I would never change just one. You want them to match.
Llamaguy
PostPosted: Tue Jun 21, 2005 5:41 am    Post subject: Reply with quote
i would think that as long as you had it aligned properly it wouldn't really matter. Just make sure you take off the plastic cover before you try and put it in. oops
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
