Tires
Codyboy
PostPosted: Tue Jun 14, 2005 6:19 am    Post subject: Tires Reply with quote
I have a 85 924 euro. And i was wondering what is the best size and the biggest tire i can put on it? I have 15 inch rims, the spider webs porsche ones . Any help would be awsome
Go hard or go home
Chrenan
PostPosted: Tue Jun 14, 2005 6:49 am    Post subject: Reply with quote
Does your car have power steering? I though some of the later models might from Europe. IF so, go as big as you want, but if not, you'll get tired at low speeds...
Codyboy
PostPosted: Tue Jun 14, 2005 7:10 am    Post subject: Reply with quote
no power steering. Tired arms dont bother me i was just wanting to make sure they will fit the rim and not rub
Go hard or go home
Codyboy
PostPosted: Tue Jun 14, 2005 3:54 pm    Post subject: Reply with quote
so what size of tires do most of u run on your 924's? i am looking for a wider tire that fills out wheel wells nicely?
Go hard or go home
Neil924
PostPosted: Tue Jun 14, 2005 10:49 pm    Post subject: Reply with quote
I'm pretty sure that 215's fit all around under the stock fenders.
MAD-924
PostPosted: Tue Jun 14, 2005 11:52 pm    Post subject: Reply with quote
I have a '79 924 with the 4 bolt 15" spiderweb wheels on it. I'm running 205/60's at all four corners. I had to roll the front fender lips so the tires would not rub. With just regular driving they were fine and would not rub but when I would push the car to it's limits, the front tires would rub. I don't know how some of you guys are able to run 215's or 225's on your cars without the tires rubbing?!?
79 924 Sebring
-nick
PostPosted: Wed Jun 15, 2005 1:17 am    Post subject: Reply with quote
^ that's surprising to hear, 205/60/15 was a stock size on the 931, althought the front lips are rolled on the 931 from the factory.
Anyway, 205/60/15 is probably the best size for a 6x15" wheel. I suppose you might need to roll the front fender lip, probably depends on the specific tire brand/model.
nick
Codyboy
PostPosted: Wed Jun 15, 2005 2:01 am    Post subject: Reply with quote
i grabbed a set of 205/60 R15 and they are so narrow and the ones i had before i am pssitive were wider. Stupid garbage man took them when i piled them up nicely beside the fence
Go hard or go home
jl924t
PostPosted: Wed Jun 15, 2005 4:18 am    Post subject: Reply with quote
I have 205/55-16's on mine.
1980 924 turbo
PostPosted: Wed Jun 15, 2005 4:35 am    Post subject: Reply with quote
You need to keep in mind that a 205/60/15 is not the same size or even the same profile from different tire manufacturers.
Kinda like shoes sizes from different shoe manufacturers.
And front clearance is different, because as others have already pointed out, some cars came with the front fender lips rolled up from the factory and other cars did not.
Codyboy
PostPosted: Wed Jun 15, 2005 8:33 am    Post subject: Reply with quote
how do u tell if they have been rolled?
Go hard or go home
numbbers
PostPosted: Wed Jun 15, 2005 9:37 am    Post subject: Reply with quote
Well, the factory tire size for the '80 931 was a 185/70/15. I run 205/60/15's on factory spiderwebs on the front, and 215/60/15's on the same rims on the back. I have the back ride height adjusters all the way down, and have no rubbing problems. I have always liked a little bigger tires on the back, it looks more like a race car.
Codyboy
PostPosted: Wed Jun 15, 2005 11:03 am    Post subject: Reply with quote
i perfer the big rears also. Places seem to like to argue with me about doing it though. Saying u should have the same size tire and all that shit all the way around. I wish some shops just did what they were told and didnt ask questions
Go hard or go home
MunkPuppy
PostPosted: Wed Jun 15, 2005 12:31 pm    Post subject: Reply with quote
if that were the case then why do the more high-performance vehicles have wider tires on the rear?!? DUH TRACTION.
They're full of it, they just want to sell you a full set.
I also have 205/55-R16s on my 931, but at one point I had 225/50R-16s on the back. Unfortunately, those were REALLY shitty tires; they had sidewalls so soft that I couldn't corner very well and the back end would float on straights.
Just keep in mind that wider tires like to follow road grooves a lot more
'80 931 FOR SALE
-Anton Szandor LaVey
Codyboy
PostPosted: Wed Jun 15, 2005 2:57 pm    Post subject: Reply with quote
were the 931 and 924 body style and fender space relativly the same?
Go hard or go home
