17" wheels for a 931
79turbo
PostPosted: Tue Apr 19, 2005 4:50 am    Post subject: 17" wheels for a 931 Reply with quote
Hi I have a 1979 euroedition 931, and I just bought myself a 17" rims.
the front wheels are 7,5" wide
and the rears are 9" wide
do you guys know anybody who has tried this on his car. or will I just have to get a widebody kit so the rims will fit.
I've already ordered it, but they haven't arrived yet.
1979 porsche 924 turbo (euro)
My924gtc
PostPosted: Tue Apr 19, 2005 8:20 pm    Post subject: Reply with quote
Might as well start saving your pennies cuz I see a body kit purchase in your 'not so distant' future
MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands"
CBass
PostPosted: Tue Apr 19, 2005 11:01 pm    Post subject: Reply with quote
That depends on the offset of the wheels. If they're the correct offset, around 53mm, you should be able to sneak the fronts in with a low profile tire, although you may need to roll the fenders to keep it from rubbing. For the rears, I'm not sure if you'll need a spacer or not, but it'd be a rather tight squeeze under any circumstances. Again, rolling the fenders may be necessary.
If they're an off the shelf generic wheel that isn't the correct offset, they probably won't fit.
79turbo
PostPosted: Wed Apr 20, 2005 4:23 am    Post subject: Reply with quote
ok thanks, the wheels got to the country today, but they are with the customs now, I will keep you posted.
I don't know if it's good or bad but my car has koni adjustables dampers and lowering springs.
PostPosted: Wed Apr 20, 2005 4:11 pm    Post subject: Reply with quote
Wheels that large are not recommended with use with four lugs because stress could exceed the design strength of the lug bolts or wheels and cause a sudden failure under load.
In other words, when turning hard, the wheels could fall/break off.
Warwick
PostPosted: Thu Jun 02, 2005 4:57 am    Post subject: Reply with quote
Did the wheels fit?
-78 924 NA
7x17 rims et 35 with 9 mm spacer front 34 mm rear.
Working on 5-bolt swap and supercharger kit.
denis durrell
PostPosted: Tue Jun 14, 2005 4:37 pm    Post subject: Reply with quote
yeah, what's the offset, any pics?
denis d.
san francisco, usa
83 944 LZ7Z (Gemini Grey)
86 944 LA1Y (Beige metallic, auto)
87 BMW 325es black, 5sp, lsd
78 924 red, the cops got it with me in it, in 2002
