ryson
Posted: Mon Jun 13, 2005 8:20 pm Post subject: what is hot and cold start? |
im learning so can u tell me what a cold start, hot start and what to do? _________________ 1977 porsche 924
1978 porsche 924
1983 porsche 944 |
chris24
Posted: Mon Jun 13, 2005 8:28 pm Post subject: |
I think ozzie meant, when you start the engine from cold (i.e. not been running for a while and the engine block feels cold) and when you start the engine from hot (say switching it off and then starting the engine again 5 minutes later when it is still at operating temperature (around 80degreesC??).
ASIDE - If you leave it more than 20minutes it can be then difficult to start if you have the hot start problem -
http://www.924.org/techsection/technical.htm
got to fuel emission exhaust then click on hot start problem fix if you want to read about it. _________________ 1983 - 924 (185K miles) - not mint
1990 - 944S2 cab (52K miles) |
tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Mon Jun 13, 2005 9:03 pm Post subject: |
Ryson,
Please update your profile with your location (never know, maybe someone else on the board is just around the corner) & update your signature with your vehicle year & type (924 N/A - naturally aspirated or non-turbo - or 924 Turbo, also known as the 931). These 2 things will save having to ask where you are & what you have.
Thanks... _________________ TJ
Silver '82 924 NA 5-Speed Manual |
Neil924
Posted: Tue Jun 14, 2005 12:41 am Post subject: |
| chris24 wrote: | I think ozzie meant, when you start the engine from cold (i.e. not been running for a while and the engine block feels cold) and when you start the engine from hot (say switching it off and then starting the engine again 5 minutes later when it is still at operating temperature (around 80degreesC??).
got to fuel emission exhaust then click on hot start problem fix if you want to read about it. |
http://www.924.org/techsection/GarageFAQ.htm |
