stamp
Joined: 21 Jan 2004 Posts: 50 Location: Springfield, Or
Posted: Sun May 22, 2005 1:56 pm Post subject: bleeding sequence |
hi, I've got an `80 931 5spd and I need to bleed the brakes and clutch...
what would be the correct sequence for the bleed process???
TIA
r0adawg |
Posted: Sun May 22, 2005 2:03 pm Post subject: |
brakes then clutch. _________________ 3 928s, |
924 turbo
Posted: Sun May 22, 2005 5:14 pm Post subject: |
Rear passenger, rear driver, front passenger, front driver, then clutch. _________________ Jon Furst |
stamp
Posted: Tue May 24, 2005 11:07 am Post subject: |
thanks much for the replys... not it off to get some fluid.
THANKS AGAIN |
CMXXXI
Posted: Wed May 25, 2005 4:40 am Post subject: |
The key to the sequence is to start at the farthest point from the master cylinder and work to the closest. If you do it this way, it will work on all vehicles, RHD or LHD...forget about driver side or passenger side reference, not all RHD vehicles have the MC on the left.
...Oh, and don't forget to constantly top off the reservoir as you go, or else you may find yourself sucking air and having to start all over again. _________________ '79 Eurospec 931 |
numbbers
Posted: Wed May 25, 2005 9:21 am Post subject: |
Be sure to read the previous posts and the tech section on bleeding the clutch, or you will be there for hours. _________________ 1980 924 Turbo |
