Posted: Mon May 02, 2005 12:58 pm Post subject: 928 update |
Well I figured that I would give an update on the 928, specifically for Dennis :p
I think I have found out what the issue is, the car was running UBER rich at idle, and when I would rev it the O2 sensor would drop off to virtually no voltage, I then found out that a diaphram in the dampener has a hole and raw fuel was being sucked DIRECTLY into the intake just after the trottle plate,
I will be replacing that early this week and hopefully that will cure it.
Thanx for the help btw dennis. _________________ 3 928s, |
924guy
Posted: Mon May 02, 2005 9:35 pm Post subject: |
wow. hopefully thatll do it, well cross our fingers for ya, maybe make a small sacrifice to the porsche gods even..  _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
