car idling too high
timstar92404
PostPosted: Sat Apr 09, 2005 6:05 pm    Post subject: car idling too high Reply with quote
My car has been parked for some time now and it idles too high.
there is barely any gas in the tank reads zero and it idles close to 2000 rpm or over 2000 rpm
it used to idle around 1100-1200 rpm still high but now its way too high.
could it be due to the car not been driven for so long and barely any gas in the tank?
78 924 sold.
85.5 944
chris24
PostPosted: Sat Apr 09, 2005 10:41 pm    Post subject: Reply with quote
You could have a look to see if your auxillary air valve is getting power when the engine is on and hence closing, or you could put 12 across it and see if it closes if you took it out i guess. I wonder if the cold start valve could cause it if it was always on, it should only have voltage across it with ignition in 'start' position. I doubt it is going to be due to low fuel.
Chris
1983 - 924 (185K miles) - not mint
1990 - 944S2 cab (52K miles)
timstar92404
PostPosted: Sun Apr 10, 2005 10:25 am    Post subject: Reply with quote
can't I just adjust the idle speed. hanyes says you turn the screw on the throtle body to adjust it. I'm not really sure which screw.
78 924 sold.
85.5 944
PostPosted: Sun Apr 10, 2005 3:49 pm    Post subject: Reply with quote
we will discuss this tomorrow tim
3 928s,
chris24
PostPosted: Mon Apr 11, 2005 2:11 am    Post subject: Reply with quote
I really doubt it, that should not be the reason it is idling high, there must be something else for it to change from 1100 to 3000. I think you may find out tomorrow!
PostPosted: Mon Apr 11, 2005 6:15 am    Post subject: Reply with quote
tim had stated that his CO mix was high and JUST under the limit for aircare, so when I went there today I leaned the mix by about 1/4 turn and that should fix the problem, I forgot how nice the flowmaster sounded on these cars.
3 928s,
augidog
PostPosted: Mon Apr 11, 2005 10:29 am    Post subject: Reply with quote
I'm looking for a new muffler. Was it the 60 series?
PostPosted: Mon Apr 11, 2005 10:30 am    Post subject: Reply with quote
nope it was a 40 series,
3 928s,
Porscheaddiction
PostPosted: Sat Apr 16, 2005 3:46 am    Post subject: Reply with quote
I now have developed this high idle about 2000 rpm...what could cause this and whts the best way to go about correcting it?
Thanks Chris.
1981 924 NA (Restoring mode)
1984 928S (Enjoying the driving season)
timstar92404
PostPosted: Sat Apr 16, 2005 6:41 am    Post subject: Reply with quote
my idle was at 2000 also I think you just adjust the screw on the throttle body.
78 924 sold.
85.5 944
Porscheaddiction
PostPosted: Sun Apr 17, 2005 12:05 pm    Post subject: Reply with quote
ok I made a mistake, I observed the following...when I 1st start my car it idles at about a 1000rpm after the car warms up my idle increase to about 1500rpm. I tried that throttle body screw its all the way in ...if I back it out it increases the idle. .. All this began when I replaced all my vaccum lines ..any corelation with this perhaps? Is there another way to adjust the idle speed? I saw something about disconecting the idle controll plug and bridging it. then adjusting the idle then plugging in the idle controll plug back in....The idle adjust is that the screw on the throttle body as ur facing the engine?
Thanks.
Chris
augidog
PostPosted: Sun Apr 17, 2005 12:16 pm    Post subject: Reply with quote
Thanks.
Chris
I bet your timing is off after the new vacuum lines.
Porscheaddiction
PostPosted: Sun Apr 17, 2005 12:23 pm    Post subject: Reply with quote
Your talking about the ignition timing right ? via the rotor/distriibutor?..ok I have the specs for the timing..to check/adjust this is a timing light mandatory?
Thanks Chris.
Porscheaddiction
PostPosted: Tue Apr 19, 2005 12:33 am    Post subject: Reply with quote
Ok everything I have read says the idle has to be adjusted before checking the timing? How is the idle adjusted ?? haynes is kind of vague What I can make out is the EIS module has to be unpluged then the idle speed can be adjusted...Where is the idle speed adjustment? is that the bypass screw on the throttle body itself?
Thanks.
augidog
PostPosted: Tue Apr 19, 2005 10:01 am    Post subject: Reply with quote
Thanks Chris.
Yes, a light will be heplful.
If it ran well before your hoses were changed , make sure they are hooked up correctly first before you move the distributor.
If they are:
Do your timing, check your idle,check your timing, check your idle.
