Wheel Cleaner
numbbers
PostPosted: Thu Mar 31, 2005 10:37 am    Post subject: Wheel Cleaner Reply with quote
Anybody know of a good product for cleaning brake dust off of the spiderwebs. I have tried several products, and they either don't work, or they damage the finish on the wheels. My spiderwebs are powder coated, and I don't want to damage them, but I am tired of having to scrub each spoke to get rid of brake dust.
PostPosted: Thu Mar 31, 2005 11:27 am    Post subject: Reply with quote
I don't have the answer for you - just a thought..
I just recently cleaned an impressive accumulation of brake dust off the backs of 2 Fuchs wheels in preparation for mounting-balancing new tires (so they'd be able to stick weights on the backside). I did it the old fashioned way - SimpleGreen sprayed on, allowed to soak, scrubbed with a ScotchBrite pad, repeat. Time consuming and no fun and it got me thinking. Once clean, could you spray the cleaned surface with teflon spray to keep future accumulations of brake dust from sticking and/or to at least make it easier to remove the stuff next time? Anyone done this or thought of doing it?
PostPosted: Thu Mar 31, 2005 5:32 pm    Post subject: Reply with quote
Try insect repellant. Takes permanent ink off telephone cabinets. (graffiti)
**I'd test an area first!
PostPosted: Fri Apr 01, 2005 1:09 am    Post subject: Reply with quote
I used Mother's aluminum wheel treatment. With the wheels off, I sprayed it on and let it sit for a couple of minutes, then hit it with a 2500 PSI power sprayer. It did an OK job, but to do it right, it's even better to just hit the wheels with a bottle brush (after applying the Mothers and before power spraying. Part of the problem with doing it with the wheels on is that the cleaner will tend to run/drip down and not stay evenly applied to the problem areas.
MALUKIA3
PostPosted: Fri Apr 01, 2005 2:05 am    Post subject: Reply with quote
I've used a product called (or made by) P21S on my bike. Does a real nice job getting the road grime, brake dust and chain lube off of my bike. Have not tried it on the spiderwebs.
Didn't harm the paint or the powder coat.
Don
79 n/a
Minus000
PostPosted: Fri Apr 01, 2005 8:11 am    Post subject: Reply with quote
I have used WD40 on my alloys. It does the trick great, spray it on and it just wipes brakedust right off. I imagine with spider webs though you would still need to scrub with a soft brush. You could always power coat the center black. Its a hot look right now.
joe
PostPosted: Fri Apr 01, 2005 9:05 am    Post subject: Reply with quote
What about using a sandblaster?
like the ones they use in machine shops to clean up heads. I saw a spray gun the other day you hook up to a compressor and it somehow sprays sand.
CMXXXI
PostPosted: Fri Apr 01, 2005 9:09 am    Post subject: Reply with quote
joe wrote:
...sandblast...
He wants to keep the finish and remove the dirt and brake dust. Blasting with any sort of media (sand, walnut shells, glass beads, etc) will mar if not completely remove the finish.
'79 Eurospec 931
Roger
PostPosted: Fri Apr 01, 2005 11:32 am    Post subject: Reply with quote
Costco sells a degreaser I think its called Oil Eater. It comes in a White plastic jug with a red label. It did a great job cleaning the road grim off my wheels.
1981 924 NA
numbbers
PostPosted: Fri Apr 01, 2005 12:08 pm    Post subject: Reply with quote
Well you know, I have heard, that in NASCAR, they spray the wheels with PAM, to keep the brake dust from sticking. I guess I could try it, but it seems like that the PAM would just attract the dust.
My924gtc
PostPosted: Fri Apr 01, 2005 12:13 pm    Post subject: Reply with quote
I think you are correct there but the dust will be on the PAM, and not cooked onto the wheels. It will wash right off along with the PAM.
MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands"
