931 engine rebuild?
mustangporsche
PostPosted: Wed Mar 02, 2005 3:57 pm    Post subject: 931 engine rebuild? Reply with quote
Ok this if for those of you who have rebuilt your 931 engine. Is the 931 engine very difficult to rebuild. I am just wondering, because I am thinking mine is going to need to before long, its making lifter noise and some other strange noises, off and on. I am just not sure about this engine? I have built a few ford v8s and a 4 cyl eagle talon turbo. But I don’t really know too much about these engines? Anyone care to comment? What was your rebuild cost, are parts crazy just because it’s a Porsche? Thanks heath
PostPosted: Wed Mar 02, 2005 4:00 pm    Post subject: Reply with quote
you can have it rebuilt for about $500 (roughly) if you do ALL the work yourself,
however before rebuild, do a compression test and a leakdown test on a warm engine,
also check/adjust the lifters as nessecary
3 928s,
mustangporsche
PostPosted: Wed Mar 02, 2005 4:21 pm    Post subject: Reply with quote
Wow 500 that’s really cheep, I was expecting 5000 ha-ha, I just spent 1200 on my ford v8 doing all the work my self. Yes I need to do a leak down test, but I don’t have one, I need to find a good one. What are good leak down rates for these engines? Do these engines have hydraulic lifters or solid?
Raceboy
PostPosted: Wed Mar 02, 2005 5:01 pm    Post subject: Reply with quote
These cars have solid lifters, adjustable with Allen key.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
CMXXXI
PostPosted: Thu Mar 03, 2005 3:51 am    Post subject: Reply with quote
Mustang,
Here's a fairly comprehensive list of parts needed for a rebuild. Prices I paid can be found in this more inclusive list and should give you a good idea of what you are up against. I'd guess that I got %90 or more of my parts on-line or off of eBay.
'79 Eurospec 931
mustangporsche
PostPosted: Thu Mar 03, 2005 8:28 am    Post subject: Reply with quote
ok thanks a lot, thats a big help
PostPosted: Thu Mar 03, 2005 1:54 pm    Post subject: Reply with quote
that is for the engine only, the turbo rebuild is not included,
I got a leakage tester where you put the cyl to TDC then it pushes air into the cyl upto 150PSI and it tells you how much is leaking and has a worn guage telling you if it is good or bad it cost me I think about $49 cdn but I could be wrong
3 928s,
mustangporsche
PostPosted: Fri Mar 04, 2005 11:18 am    Post subject: Reply with quote
oh yeah that sounds pretty good, i u dont mind, where did you get that tester??
