Frost on the inside
Getting more moisture and/or frost on the inside of 924 windows than on other cars?
I actually have other car/s that get wetter on the inside of the glass than the 924 does
19%
 19%  [ 4 ]
924 is just as wet/dry as others
19%
 19%  [ 4 ]
it's just a little more of a problem with the 924 as compared to others
19%
 19%  [ 4 ]
924 is way wetter on the glass's interior than others
42%
 42%  [ 9 ]
Total Votes : 21
PostPosted: Mon Jan 17, 2005 3:52 am    Post subject: Frost on the inside Reply with quote
With the cold weather here lately, I'm finding myself using the scraper and a squeegee more on the inside of the glass than on the outside. -Apparently due to water that's found its' way in, gone into the carpet, which then humidifies the interior air and condenses on the glass as outdoor temps drop. Standard procedure now is to drape a large towel over the dashboard and scrape the frost (squeegee if it's water) off the inside of the windsheild, then the same for the sides and rear hatch glass.
-Just imagining I'm not the only one with this problem since 924s tend to be leaky.
Anyone using any creative solutions - such as leaving the windows and/or sunroof open?
dpw928
PostPosted: Mon Jan 17, 2005 4:51 am    Post subject: Reply with quote
Smoothie,
My 78 928 5 speed gets more water in the passenger compartment than the 931. The 928 has no sunroof and the battery box is in the rear. The blower motor has a gasket below it that could be leaking or the front cowling drain could be plugged. Both are a b***h to get to and since this is my daily driver, I'll just have to live with it until I get a rebuilt turbo in the 931.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
augidog
PostPosted: Mon Jan 17, 2005 10:14 am    Post subject: Reply with quote
This is funny , I am having this problem on a historic restoration project with single pane metal glass windows. I just did some research for the homeowner.
The answer lies in the moisture content inside the car rather than bad seals holding the cold air out.
One solution is to leave a window cracked at night so the moisture can escape.
Sleykin
PostPosted: Mon Jan 17, 2005 3:33 pm    Post subject: Reply with quote
Get some fogX. Like rainex but for the inside. RainX on the outside helps with the frost problem on the outside too. Just beads of ice that are easy to see through/around.
Glenn Neff
Medford, OR
87' 924S
jpab924
PostPosted: Mon Jan 17, 2005 11:43 pm    Post subject: Reply with quote
You know, I once had a 72 superbeetle, and in the winter time I had to instruct people not to breathe in the direction of my windshield. Boy that was a fun car to drive!
PostPosted: Mon Jan 17, 2005 11:55 pm    Post subject: Reply with quote
I agree, it's because of the amount of water content in the car, usually due to leaking seals, etc. Even if it hasn't rained recently, the carpet can hold the moisture in and release it overnight. Leaving windows cracked is one of the simplest ways to clear it out (both at night and during the day, as the sun heats it up).
More motivation to fix those leaks. While I still have some small ones (hatch I think), it's gotten much much better than when I started.
Llamaguy
PostPosted: Fri Jan 21, 2005 1:11 pm    Post subject: Reply with quote
Is it possible that it is leaking through the heater? because I get it on both sides and there's nothing to let the water in the driver side as if it was from the battery tray
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
Vince Ponz
PostPosted: Sat Jan 22, 2005 12:51 am    Post subject: Reply with quote
I have a hatch leak that I cannot seal. I replaced the seal and still it leaks.
When working on the car I like to keep my hands clean and always use a roll of toilet paper in the car. Well it fell on the rear floor and recently when I went to use the paper to clean the windshield I could not get the roll off the floor. It soaked up all the water and was frozen solid. I guess I will have to wait till spring to get it off.
Anybody got change of a 5 dollar bill. I just got the runs.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
augidog
PostPosted: Mon Jan 24, 2005 9:14 am    Post subject: Reply with quote
I hear that "Olestra "the chemical in non fat chips , will give you a hatch leak.
Better start there first.
Keep another roll handy just in case
PostPosted: Mon Jan 24, 2005 5:14 pm    Post subject: Reply with quote
Gives a new image of "POS"
LOL!
PostPosted: Thu Jan 27, 2005 2:16 am    Post subject: Reply with quote
Whoa yeah - I'm in need of change for a twenty after that cup of McDonald's coffee this morning .
Hey, the quick-easy fix of leaving the windows opened a crack's been solving the glass-inside moisture problem - keeping the moisure in the carpet where it belongs. Just a 1/4" opening's all that's needed and it doesn't let tooo much rain or snow in.
goturbo
PostPosted: Wed Feb 09, 2005 1:25 pm    Post subject: Reply with quote
Had to laugh when I saw this topic I've had a towel freeze to the floor-are we crazy? It was so bad with my car that in the summer I would run an extension cord out to the car and have a couple of small fans running all night long to help dry it out after we had a couple days of rain. Even after I repalced the sunroof seals it leaked, so I silly-coned it shut. It appeared that it was leaking at the sheet metal joint where everything up top comes together, right in the corner of the sunroof. Whoda Thunk it.
Worst part of it is, when I pulled all that stuff out when I started the restoration, I could not believe that I was driving around with that nastyness in my car. If the health department would have found out about that, they would have set up a tent around my garage and condemned the whole place.
Food for thought...
PostPosted: Sun Mar 20, 2005 8:45 am    Post subject: Reply with quote
Having a giggle here about the freezing towels/toilet paper.
In the great land of OZ a person has to go out of ones way to find a sub zero climate.
blargonator
PostPosted: Sun Mar 20, 2005 5:29 pm    Post subject: Reply with quote
i get a lot of condensation right under my dash, of course my windshield looks like a shower door. i have a little hole in the rear hatch seal near the bottom. i generally allow the snow to build up though
View user's profile Send private message AIM Address MSN Messenger
Llamaguy
PostPosted: Tue May 24, 2005 8:29 am    Post subject: Reply with quote
I just thought of this, if our cars are so moisty, we should use them as a giant humidor! although I'm sure theres more to it.
