cakemakerman Guest
Posted: Fri Mar 15, 2002 1:06 am Post subject: |
| so maybe i should go with a propane engine? Its cleaner, and someone said you could get more power from propane then gasoline. can anyone verify this? |
Rick MacLaren Guest
Posted: Fri Mar 15, 2002 3:03 am Post subject: |
| You can turbocharge propane engines and get less detonation cause it burns cooler. |
Cbass Guest
Posted: Fri Mar 15, 2002 8:41 pm Post subject: |
There is a big difference between hydrogen powered engines and fuel cell powered electric engines. Hydrogen is just as easy to use as gasoline for internal combustion. You just need a venturi system to create the proper fuel air mixture. It's really easy when you have fuel injection.
