Rear stub axel
kidporsche
PostPosted: Mon Dec 13, 2004 11:15 pm    Post subject: Rear stub axel Reply with quote
Trying to replace my rear wheel bearings, the LH stub axel will not come out. I don't have a brg puller, any other suggestions?
Thanks
Chris
1981 924 - RoW (Australian) spec
AznDrgn
PostPosted: Tue Dec 14, 2004 2:44 am    Post subject: Reply with quote
First make sure you got all the hardware off that is holding it. Put the nut back on like 2 or 3 threads and then put a 2x4 block on it and hit it with a big hammer.
-'87 Jeep Cherokee 4.0L 6" of lift 33" Super Swampers
-'83 Callaway 944 2.5L turbo, 300HP, 1 of 42 ever made
kidporsche
PostPosted: Tue Dec 14, 2004 5:32 am    Post subject: Reply with quote
As far as I can see, once I remove the nut and drum at the front and the half-shaft at the rear, there shouldn't be anything to stop the stub axle. Have I missed anything?
Chris
AznDrgn
PostPosted: Tue Dec 14, 2004 7:57 am    Post subject: Reply with quote
That's all that's there, just whack it.
