Fuse Box
stamp
PostPosted: Fri Oct 29, 2004 4:26 am    Post subject: Fuse Box Reply with quote
I can't seem to find out where this block is referenced...
thanks for the help
Stamp
Warning, image is 1.5 meg..
PostPosted: Fri Oct 29, 2004 4:40 am    Post subject: Reply with quote
I can't tell what year your car is.
Anywho, the '82 owners manual references those as "Additional Fuses" -
From left -
1- Horn, 8A
2- Fuel Pump, 16A
3- Radiator Fan, Antenna, 16A
4- Rear Window Defogger, 25A
5- AC, Condenser Fan, 16A
6- AC Compressor, Fresh Air Fan, 25A
7- not connected
8- Power Windows, 25A
9- not connected
stamp
PostPosted: Fri Oct 29, 2004 5:34 am    Post subject: Reply with quote
oops, for got the important stuff...
1980. sticker on driver door frame says dec 1979..
and the fuel pump is correct, blew that one a while back...
thanks
Carris
PostPosted: Fri Oct 29, 2004 9:45 am    Post subject: Reply with quote
I had a 1980 and that fuse block was referenced in owners manual, and on the 924.org technical section I think. That list above looks correct, had a lot of trouble with the cooling cicuit fuse, the 3rd one.
Chris
