Xenotide
Posted: Wed Oct 27, 2004 7:51 am Post subject: What the best thing to glue down your new carpet with? |
What the best thing to glue down your new carpet with? Would a Arasol Spray glue work? I am doing all new carpet in my 924 and would like to know before I get in over my head. _________________ 1980- 924 first Porsche and Restore Project
My girl is getting painted... ABOUT TIME |
My924gtc
Posted: Wed Oct 27, 2004 8:06 am Post subject: |
3M Interior Trim Adhesive is best. You can get in aerosol cans or spray with paint gun and buy by the quart. _________________ MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands" |
Stu2j
Joined: 03 Nov 2002 Posts: 1285 Location: Virginia Beach, VA
Posted: Wed Oct 27, 2004 8:19 am Post subject: Re: What the best thing to glue down your new carpet with? |
| Xenotide wrote: | | What the best thing to glue down your new carpet with? Would a Arasol Spray glue work? I am doing all new carpet in my 924 and would like to know before I get in over my head. |
I used the 3M Adhesive in a spray can. Worked great! _________________ -Stu
924 owner since 1988
924S owner since 2002
Click here to view them: |
manouchehr
Posted: Wed Oct 27, 2004 6:44 pm Post subject: |
| I used 3M glue spray to glue down the rear seats. works great and you'll be able to pull the carpet off if you need to |
CMXXXI
Posted: Thu Oct 28, 2004 4:23 am Post subject: |
3-M makes several "strenghts" of their aerosol glue, a "Super 77", an interior trim and a hi strength trim glue. The "77" is good for paper, sheet plastic, fabric and light weight stuff, but isn't enough for headliners or things heavier. The interior trim glue doesn't hold up to heat, but the high strength trim stuff says that it can safely be used in hi temp applications like under-the-hood insulation liners and the like. All of the stuff is pretty expensive, so you might consider getting the strongest stuff and using it on everything. _________________ '79 Eurospec 931 |
