What do you use for your dash?
PostPosted: Wed Oct 20, 2004 2:42 pm    Post subject: What do you use for your dash? Reply with quote
My car came with a cloth cover that velcro's onto the dash. I'm considering a dash cap (or waiting until My924gtc comes up with a fiberglass replacement). I'd like to hear from those of you using dash caps...what do you like about 'em, what do you hate about 'em?
Also, I'm planning to add 3 vdo gauges, a water temp, a volt meter, and a vacuum meter. I can wait for My924gtc to come out with his dash (replacing the center speaker bezel with three 2 1/16 gauge holders), or I can go with a three-pod bezel from eGuages, or I can go with three generic a-pillar pods from APC (www.sfxperformance.com/parts/APC107062.htm). What are you using??? Thoughts, opinions, comments???
PostPosted: Wed Oct 20, 2004 10:31 pm    Post subject: Reply with quote
have you priced a re-skin?
I have no idea what the charge would be in your part of the world but the process is relatively simple. You clean up the dash and fill any holes and cracks. Then you vacuum shrink a new skin over the dash. The process with fibreglass or carbonfibre is called vacuum-bagging although commercially it's probably more complicated than just sticking the mould (dash) in a plastic bag and sucking the air out.
I don't know but I'd be surprised if that wasn't how they skinned the dash originally.
Be interesting to know how much it would be.
You're welcome to check out my dash cover (I have the $80 plastic one) when we meet up.
Personally, I wouldn't bother with those gauges, especially not on a street car. Don't you already have them anyway? Well, except for vacuum, but how useful is manifold pressure anyway, unless you're running forced induction? As for how to mount them, I'd stick with the stock VDO gauges in the stock center dash cluster - looks much better. Well, I suppose some cars had a clock on the right hand side of the center cluster, and AC in the center (my turbo does), you could replace the AC control or clock with a voltmeter as desired.
But I still think stock looks best. Check out my dash:
http://www.vaughanscott.com/construction.htm#INTERIOR
PostPosted: Wed Oct 20, 2004 11:44 pm    Post subject: Reply with quote
Depending on what I decide to do about the A/C, I may take out the A/C switch and the standard clock and replace them with a Vacuum gauge and Volt Meter gauge. Once I get the new sound system installed, the analog clock will be somewhat superfluous (although I still like the way it looks).
There is no stock voltmeter, just the battery idiot light, so I want a real volt meter. Vacuum gauge would just be plain cool, no two ways about it I was considering a water temp gauge because the standard temp meter on the stock multi-gauge doesn't have temperature readouts, just cold and hot with a few lines.
I just wish there was a more effective use of the center speaker area...it would really cool to have the space serve some function (since I don't intend to install a speaker there). I thought that having a nice, professional gauge bezel for extra gauges in place of the speaker grill would be nice so I could keep everything else stock. Doesn't look like such a thing exists.
From what I've seen in the pix, the plastic dash caps seem to look pretty good...hard to tell it's not standard. I'll be interested to see it in person.
My924gtc
PostPosted: Thu Oct 21, 2004 12:11 am    Post subject: Reply with quote
Dan I have an ABS dash cover you could check out. I should have everything transfered to the shop by the end of the weekend if you want to stop by again.
Plan on moving cars all day Saturday and the rest of the parts Sunday after I return from another trip to IN.
MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands"
PostPosted: Thu Oct 21, 2004 12:14 am    Post subject: Reply with quote
Ah, OK, you have the later factory AC - I'd charge it up and keep it. Have mine converted to 134, fairly easy to do, and well worth it in the summer. Do need to tint the windows to keep the heat levels under control, though.
jpab924
PostPosted: Thu Oct 21, 2004 12:03 pm    Post subject: Re: What do you use for your dash? Reply with quote
Good idea Mark! About time somebody follows through with it. I want my dash back! JK you can keep it.
I actually have seen pics somewhere with the center speaker being used as a guage pod holder. It looks good imo. I`ll poke around and see if I can find that pic....
The Fife
PostPosted: Thu Oct 21, 2004 12:58 pm    Post subject: Reply with quote
I'll probably do this someday:
http://forums.rennlist.com/rennforums/showthread.php?t=150402&page=3&pp=15
PostPosted: Thu Oct 21, 2004 1:18 pm    Post subject: Reply with quote
How good is Dick Ruddell's avatar!
PostPosted: Thu Oct 21, 2004 3:53 pm    Post subject: Reply with quote
Ive taken mine out so many times though I had a dash cap I took it off and also took off the speaker cover that some use as a guage holder and I filled that big hole there with fiberglass and I had cracks on the top also these I ground out with my dremel tool and filled the trough with fiberglass
then I just smooth the hole top with fine grit paper the plastic is thicker than you think and can be light sanded smooth.
PostPosted: Fri Oct 22, 2004 12:36 pm    Post subject: Reply with quote
Reskins are too expensive...about $1000 here in the states. I only spent $1200 on the car to begin with...I don't mind doubling my investment, but not on a stupid dash board! I can buy a lot of other cooler stuff for $1K.
So about the factory A/C...will a local shop be capable of doing the conversion if I supply the parts? How difficult is it to do on my own?
Sleykin
PostPosted: Fri Oct 22, 2004 2:07 pm    Post subject: Reply with quote
The main thing to change are the O rings on the compressor manifold. They are the most prone to blow out. Pull the compressor buy the orings put it back together pump it down to ~25"HG for 30 min to an hour and charge it back up with a charge of 134A compatible oil and the proper weight of 134A. QED.
Everything else is EBS and if it isn't working as you like you can fix the rest as you go. The reciver drier will plug and cause problems if it already has a problem etc. Why change everything and replace good parts till they break? The 134A is cheap a vacuum pump and guages costs less than a shop charges to change it over. And you get some cool new tools too
I switched to 134a in mine by just pumping it down and adding 134a. Next year I had to add more freon and it blew out in short order ... pulled the compressor and replaced the O rings and pumped it down and re-charged and it is going on a year now with no trouble. Total investment about $20 in freon and O rings. I already had the pump and guages.
Glenn Neff
Medford, OR
87' 924S
PostPosted: Fri Oct 22, 2004 2:21 pm    Post subject: Reply with quote
Hmm....it would be nice if there were a how-to in the technical section. I've done a lot of light repairs, but never dug into A/C before. I don't have enough baseline knowledge of A/C in general to know where to begin troubleshooting if things don't work as expected. Haynes doesn't even bother listing how to do everything, he just tells you to take it to a pro.
In any event, I have all winter to think about it! Don't intend to spend money on A/C until it's required
Sleykin
PostPosted: Fri Oct 22, 2004 2:42 pm    Post subject: Reply with quote
A/C is just a compressor and some valves. It is not rocket science ... though you would think it is to hear the shops talk. Simple ranken heat cycle physics. Really not all it's pumped up to be (pun intended) <LOL>
If you can change a headgasket A/C is a POC.
Glenn Neff
Medford, OR
87' 924S
PostPosted: Fri Oct 22, 2004 10:08 pm    Post subject: Reply with quote
FYI, I'm likely to pick up the gauges and vacuum pump sometime by next spring, you'd be welcome to stop by to use them (the cheapest vacuum generator uses compressed air, which I have of course).
We still need to find a time and meet up - you have mail...
