Rear seats fold down?
ike229
PostPosted: Fri Oct 22, 2004 10:54 am    Post subject: Rear seats fold down? Reply with quote
I was toying around with the car earlier, and realized that the upper part of the rear seat was wobbling a little, which brings me to the question. Does the rear seat fold down? And if it does, where is the release latch to unlock it?
kye
PostPosted: Fri Oct 22, 2004 11:08 am    Post subject: Reply with quote
yes, the top half folds forward to give you more flat surface in the hatch.
the release mechanism on my ROW car is on the left hand side of the car (when looking at the rear of the seat) and it's a metal lever that is pulled towards you (ie, to the rear of the car).
mine used to have a looped handle of some kind, but now is just a metal plate on a rod, and might be tucked out of the way, but should still be accessible.
they can be a bit stiff, but trying to pull the seat towards you while pulling to release the catch can make it a bit easier.
it's funny, but when they said "Anything is Possible", that's exactly what they meant....
ike229
PostPosted: Fri Oct 22, 2004 11:25 am    Post subject: Reply with quote
well, i cant find this release mechanism.... probably because its dark outside.... but should it be visible?
PostPosted: Fri Oct 22, 2004 12:16 pm    Post subject: Reply with quote
They came with a loop of vinyl as a handle that lies forward - so you can release it from in front of the seat. The loop should be visible from the front... If you have it, just push back on the seat while pulling the loop toward the front of the car. If not, it has to be done from the back as Kye described. It's on the left side of my car (US spec, LHD) same as on Kye's, so yours should be there as well.
Sleykin
PostPosted: Fri Oct 22, 2004 2:45 pm    Post subject: Reply with quote
Mine is a round button about 1" diameter atr the top of the seat
Glenn Neff
Medford, OR
87' 924S
PostPosted: Sat Oct 23, 2004 3:00 am    Post subject: Reply with quote
In case anyone wants to duplicate the older vinyl loop handle, a pic -
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=/a174&.dnm=d9ab.jpg&.src=ph
ike229
PostPosted: Sat Oct 23, 2004 4:06 am    Post subject: Reply with quote
If the leather strap ripped off... is there still a way to unhatch the seat?
PostPosted: Sat Oct 23, 2004 4:14 am    Post subject: Reply with quote
Yeah - didn't Kye cover that procedure already?
(Except that (with my car at least), you'd push the lever forward if unlatching it from behind.)
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=a174&.dnm=fb0f.jpg&.src=ph
kye
PostPosted: Sun Oct 24, 2004 3:14 pm    Post subject: Reply with quote
oh crap.. yeah, smoothie is right, you have to push it towards the front of the car, not the back..
question: what was I thinking?
answer: I wasn't!
