front coil-over suspension for $189
AppleBit
PostPosted: Wed Oct 13, 2004 5:39 am    Post subject: front coil-over suspension for $189 Reply with quote
http://www.nolimitmotorsport.com/prod/gc7015-01
Just found...
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
PostPosted: Wed Oct 13, 2004 6:49 am    Post subject: Reply with quote
OOOOoooooooooooooo
Very cool. Anybody have a thought as to whether these might work w/400# 2" shortened springs? (not stock springs )
PostPosted: Wed Oct 13, 2004 9:27 am    Post subject: Reply with quote
emoore, if those springs you are refering to are made to fit in the factory location/hats, then the answer is no, the coil overs will have a smaller center OD but you will be able to find 400# for them.
3 928s,
My924gtc
PostPosted: Wed Oct 13, 2004 10:11 am    Post subject: Reply with quote
I'm not so sure about that Lizard.
I think the ground controls are set up to use the same diameter spring as stock. It is really just an adjustable perch that makes them what they are. Most kits I have seen use regular Eibach springs, not the small diameter ones used in say... rear coil overs.
Someone buy some and tell us what you get!
MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands"
PostPosted: Wed Oct 13, 2004 10:50 am    Post subject: Reply with quote
Pretty confused - here's GC's webpage (note that we have VW A1 front suspensions on our cars, parts are interchangeable fully):
http://www.ground-control.com/?D=c0f5eab1262be44724ec3945e9ccb9b8
Those pictured look like 2.5" race springs, as I'm using. I definitely wouldn't order without asking questions...
AppleBit
PostPosted: Wed Oct 13, 2004 11:02 am    Post subject: Reply with quote
I have coil over on front: 250 lbs
Freakin sweet
edh
PostPosted: Mon Oct 18, 2004 4:37 am    Post subject: Reply with quote
are these the same as
http://www.paragon-products.com/product_p/944arhk-r.htm
doesn't say what cjhoice of springs they come with on the nolimit website
current - '90 944S2, '00 986S,
ex - '90 944 turbo '86 924S, '88 924S
