changeworks
Posted: Sun Oct 10, 2004 2:28 am Post subject: Alterbator B+ |
Hi Guys,
Disconnected the existing cable from alt B+ and ran my test cable from there to battery +.
Alternator/battery light does not light up with engine off, engine on or engine running.
George
Glasgow
Scotland _________________ 1983 - 924.......
"A mind once stretched by a new ideal will never regain its original dimensions". |
Posted: Sun Oct 10, 2004 3:13 am Post subject: |
If you have a voltmeter, check to see if the alt's putting out >13V+.
Also - did you verify that the D+ wire (also on back of the alt) is connected? The D+ wire serves as "exciter wire" and it also lights the dashboard light. 12v+ should come from the battery to light the light when ignition's switched on and engine's not running. That 12V+ also serves as exciter current to post D+ to start the alternator charging. Once the alternator starts charging, it sends 12V+ back via D+ through the exciter wire in the other direction - so then you have ~12V+ coming from the battery and ~12V+ coming through the wire in the opposite direction from the alternators' D+, the light goes out due to no difference in potential on both sides of its' filament.
Long story short - you should see the generator light when ignition's on and engine not running. -And if the bulb is burnt out, exciter current won't get to D+ to initiate charging by the alternator. _________________ "..it's made in Germany. You know the Germans always make good stuff."
changeworks
Posted: Sat Oct 16, 2004 7:00 pm Post subject: Alternator B¤ |
Sorry guys
l am in Turkey for two weeks- until 26th Oct- will get back to car problem when l get home to frozen Scotland-
Cheers
George
Marmaris
Turkey _________________ 1983 - 924.......
changeworks
Posted: Tue Nov 30, 2004 11:39 pm Post subject: Alternator B+ |
Hi Guys,
Sorry for the delay in getting back to you,
Haveing checked t he cable from battery to alternator, it was wasted, the movement must have finished it off.
Replaced it thinking that the problem was resolved,
wasnt.....had the alternator re-checked and it was well and truely knackered, l reckon the first refurbishment job done was a con, but thats in the past.....
Managed to get hold of a new one, totally by accident and that resolved that problem,
cheers for all your input,
George Wylie
Glasgow
Scotland
1983 924 _________________ 1983 - 924.......
augidog
Posted: Fri Dec 03, 2004 12:21 pm Post subject: Re: Alternator B+ |
| changeworks wrote: |
wasnt.....had the alternator re-checked and it was well and truely knackered, |
knackered [from knacker] adj :
tired, dead tired, worn out, “I’m bloody knackered”, also broken beyond repair, “that car’s knackered”, syn. _________________ 1978 924 95 mile daily driver.
changeworks
Posted: Fri Dec 03, 2004 6:48 pm Post subject: Alt B+ Knackered |
I originally typed in completely shagged and then changed it to knackered.......
Knackered - okay its a horse (power) thing, ye olde knacker used to purchase clapped out horses in his knackers yard (scrap yard) and sell them on for refurbishment, although l think they were refurbed as glue ect.......
Nothing changes really, breeds come and go, the knackers yard still waits for all things............
My problem, the knacker was disguised as a mechanic
Yep, tired, worn out, knacked, useless.................
Maybe should have run with completely shagged....or ...fubar
All these technical terms frighten me
have an incredibly good day
George
Glasgow
A well bred 1983 924 _________________ 1983 - 924.......
